Here's the spec sheet for the fans. I'm kind of ignorant on how to understand it.
Those fans are most certainly undersized for your application. Assuming similar static pressure drop to my fan combo (210 Pa, or about 21.5 mm H2O), you are only getting about 400 CFM per fan through the radiator for about 800 CFM total, which is likely going to be insufficient in a lot of cases, especially if you add AC on top of that. Add a turbo and I guarantee that would cause issues. You basically have enough fan to run the AC and not much more.
The SPAL 19" fan should pull triple that airflow even with the radiator, condenser, and 3rd cooler stacked on it. I estimate about 2,800 CFM in my setup.
I would recommend giving the Explorer fan or the SPAL Camaro fan a shot. Both should have way more than enough airflow for your needs.
