Turbocharger Torn
Jpablo
Switzerland
Hi!
Unfortunately, the weld seam after the turbocharger is torn. I drive a 2013 JK Sahara 2.8L
Has anyone had this problem? How much would it cost to repair it?
Thanks in advance!!
Hi!
Thanks in advance!!
Unfortunately this forum likely will not be able to answer this. This forum is for 1997-2006 Wrangler's. Not only is yours not a TJ, it is also an engine that likely no one here in the United States has dealt with.
You'll probably need to remove the piece and have it welded by someone capable of doing it right. If you brought them the piece to weld, it wouldn't cost you much. R&R the piece plus weld raises the price obviously.
