I have a reasonably stock 1998 TJ 2.4L that has a 4 inch lift, and the 29inch tires that I got with it feel like I'm disgracing it, so I've been looking at upgrading.
Everything is on a budget, but I'm not trying to make stupid mistakes and cut corners that could come back to bite me, so I've purchased a set of new wheels, upgrading to 33s. I know I'm going to have to upgrade the diffs to 5.13s because the 4cyl will just drag, and I'm looking into the upgrade I need for my rear axle.
I know Dana 35s are a little of a guessing game, so I was looking to switch them to chromoloy which would be stronger than stock 44s. I was reading the description from extremeterrain's page for a kit, which said,
"If your Jeep is sluggish with bigger tires, then this rear axle kit is a cost effective way to solve that problem without upgrading the differential. "
I haven't seen anything about stronger axles improving sluggishness. Is this true? and how does that work?
Could I just upgrade the axles with this ~$350 kit and install them myself instead of buying ~$500 5.13s and spending ~>$1,000 to get them installed?
