So I've got to replace my bent trackbar. I ordered a JKS OGS125 Adjustable Track Bar. Problem is I forgot I had to drill out the frame side upper track bar hole to 5/8 for the bent track bar and the new one has a 9/16 bolt. Is there some kind of bracket I can get to adapt this? I've seen adapters from Clayton Offroad with a double shear design with rotates the bolt orientation to be parallel with the ground instead of vertically, but for some reason JKS has the adjustable end on the axle side meaning that (as far as I can deduce) the double-shear bracket design for the upper mount won't work. Pictures for reference below. What should I do?
Double-Shear design that won't work the JKS track bar.
JKS OGS125 Track Bar with adjustable rod end on the axle-side and vertically oriented frame-side bolt.
