May be a dumb question, but it is time for me to replace the torque boxes on my project TJ, since the body mounts in the center have rusted through completely. I understand how to replace the entire piece, drilling out the pinch/spot welds, and that it should be pinch welded back on with some body panel adhesive. I saw one thread where someone used rivets and said it held up ok...has anyone used bolts and washers in the old drilled out pinch weld holes? I would think it would be just as strong as a small pinch weld, since there is so many of them. May be a dumb idea, but knowing that I lack a welder (but have dang near everything else) I was curious what everyone else thought or if anyone else has done it that way.
Side note-I know that welding is the preferred method, period. Just seeing if someone has ever done an alternative.
this is a budget $400 TJ that I bought from my boss with a 2.5 with a broken piston skirt, so trying to do small things to bring it back to life on a budget.
