Valve cover washer
jgaz
AZ
I'm in the process of replacing my valve cover gasket with the fel pro gasket and grommets. During the tear down I discovered one of the special metal washers was missing along with the grommet. The grommet is no problem since it comes with the gasket set but I need an OEM washer with integral sleeve.
Does anyone know if this washer is available separately? If so, do you have a part number? I have the service manual but no parts manual. The parts man at the dealer says it's not listed but I'm not sure he even looked.
My Jeep is a 2006 LJ with the 4.0l engine.
Also, if anyone has a link to a 2006, downloadable parts manual it would be much appreciated. I'm not even sure such a thing exists but I thought I'd ask.
Thanks!
Chris,
It's hard to tell from the eBay pics, but those appear to be the rubber grommets,not the washer/sleeve piece I'm looking for.
We are Mopar only shows using RTV not a gasket unless I'm looking in the wrong place.
I wouldn't be surprised if the part you're looking for is not available. I've found that is the case with a lot of little oddball parts.
Hmmm, I wish I knew what exactly it was you're talking about. Any chance you have an image? It's been a while since I did my valve cover gasket.
Here is a pic of the missing part
I thought you said it was missing...it's right there in your pic. j/k
Good luck finding that.
Pretty certain my ACE Hardware has those. Not sure what they're called, but I know I've seen them before.
Go down to your local ACE Hardware and look, I'll bet you'll get lucky.
I can pretty much guarantee that you won't find that in any part diagrams. The next best place would of course be eBay.
Reactions: jgaz
The missing part didn't show up in my picture so I tool a pic of of one of the 14 that I still have. Lol!
Great idea on Ace Hardware.
I did find a good parts man to help. The part is discontinued but is called a "torque limiter sleeve" in the parts book.
Thank you all!
A torque limiter sleeve, interesting! I never would have known that.
Thanks guys for jogging my memory. I was too focused on getting the OEM part to think outside the box. I had two of the pictured rubber mounts in my junk box. I pulled one apart and shortened the sleeve.
If I hadn't had these "in stock" I'm sure Ace Hardware would have had something.
I just looked in my toolbox and I have a bunch of these I've collected from over the years (from Jeeps, motorcycles and other cars). They're pretty easy to find at ACE as well if I remember correctly.
Glad you got it all figured out!
Me too. I just went brain dead for a bit.
Oh crap! It might have been a senior moment.
Chris. If you still have this part, could I purchase one from you? I had no luck at ACE. Will check junk yards in the meantime.
Hi Chris, I need to buy one along with the plastic rubber part, could you sell one to me? my email is [email protected]
