Well, I didn't want to have to do this, but after more than 1 year and still no solution, I need the opinions of the forum members. I have a vibration in my TJ that begins to be noticeable around 55, but is "liveable" up to 65. Past 65 the vibration increases dramatically and is no longer just a noise but an actual shaking feeling. After 70 it feels like the jeep is going to shake apart and you can feel the vibration even in the gas pedal and steering wheel. Now that the TJ has somehow managed to become my DD, I need to drive to NYC once this summer and to Toronto as well for a wedding and need something that can drive on the highway without being run off the road by tractor trailers going 70 plus.
This is the relevant info you need to know....
Jeep had no front driveshaft in it when I bought it, and the t case apparently had a chain that needed to be replaced. The jeep vibrates the same before and after getting a new (used) t case and front driveshaft.
I added new front shocks, front track bar, front sway bar links, new tie rod, did the alignment, changed one front lower control arm, the other front lower was changed by a PO, the upper control arm bushings look okay but I didn't check the front uppers for torque or do anything with them. I didn't touch the rear suspension.
I loaded up the tires into a truck and had them remounted and re balanced at pepboys for 65 bucks and then I rotated them on the jeep, it decreased the vibration but it's still really bad after 70. Because I'm always suspicious of shops I then bought centramatics to see if balancing was an issue. After 100 miles I ditched the centramatics and swapped out the tires between my two jeeps at the time. The wheels and tires that were on my other jeep were balanced by goodyear who charged me at 200$ for 5 tires, and of course the effing weights fell off within a year. But there were no vibes on my other jeep. Low and behold swapping out the tires and rims made zero difference literally zero.
Then I pulled the rear driveshaft and went for a drive it felt better at 70, but still it didn't solve the issue. Then after changing the u joints on the rear driveshaft and reinstalling it was back to the same vibration.
Now my thinking is the rear driveshaft needs to be re balanced or maybe there is a component in the rear that vibrates worse when power is being sent to the rear wheels. I am at a loss as to what to do. I am not a mechanic by any means. But I am damn well ready to replace any parts I have to within my ability. I am going to take it to our trusted local small town mechanic who is truly a straight shooting guy who won't fuck me. We will see what he says but I'm honestly thinking of just pulling the rear driveshaft again if I can't get the jeep straightened out before my NYC trip.
Thanks for reading the wall
- 4 popper.
- 4 popper.
