My guess is that they will all make sound which my crappy hearing cannot discern. The ringing in my ears keeps me from hearing the highs and lows, right in the middle. Blessing is, it severely cuts down on the wind noise.
Don't do it. Bigger is not always better. Diminishing the sound from your front speakers with huge rear speakers, right at your ears, won't improve your overall sound fidelity. Imagine a home entertainment system with huge rear speakers, and normal front speakers. Then, think of how good a Bose system sounds, with all the speakers the same size.
I see your point, but some larger speakers give better sound quality and the front vs rear speaker volume can be controlled with the fader.
speaker size, as long as they arent the crappy 4x6, wont affect volume as much as they will affect range. generally speaking, 6.5's have deeper mid range lows than 5.25's. the additional bass out of a 6.5 in an over head speaker wont force you to fade any more than a 5.25, it will just sound better.
ie. polk db series
5.25 = 55hz-22khz
6.5 = 40hz-22khz
both speakers have the same power handling specs and very similar sensitivity levels. the difference is the 6.5 has a deeper low end.
Neither one of those speakers is going to play anything under 80-90hz with authority
I like my Infinity Kappa's
I blew those things out in one week.
I've had mine for 5 years and put plenty of power to them. Still sound great.
Try using a 1500 watt Alpine PDX-V9 amp with them. lol. I've had my CDT'S for over 10 years and they have taken the best of my Alpine amp without a problem. I guess that's a testament to how they are made. The Infinity Kappa's are rated at 55 Watts RMS, like the Kickers, where as my CDT'S were rated at 120 watt RMS. After 10 years, I was so happy and impressed with them, that I upgraded all 4 speakers to the latest 140 watt RMS version when they were on sale. Kickers and Kappas just leave no real room to grow. They may sound fine unless you put any decent amp to them. I believe I spent $100 dollars a pair originally for my CDT'S. Plus, they are made in California, where we know our music. I'll take USA quality, especially USA California where the best quality artists like EVH was made over any Over Seas made junk. But, that's just me.
yes, massively overpowering a speaker, 55w rms speaker running off a 100w rms amp will destroy the speaker in minimal time. that is an application error, not the fault of the speaker.
thats a nice amp, but is the 1% THD spec accurate? that seems crazy high and may be the way they were able to get the 100w rms spec.
the eclipse xa4000 that I have been powering my polk momo's with for close to 20 years is spec'ed at 125w rms x4 at .05% THD.
perhaps they only give specs for THD for the mono channel, but 1% THD output would be a shame with high quality speakers.
Definitely on you if you 'blew those things out in a week'. I don't own them, but have read nothing but excellent reviews of the Kappa series. If you blew them out, they must have been installed incorrectly. Too much or too little power can ruin speakers. Need to review how much power they're rated for, get the crossover set correctly (if needed).
