https://wranglertjforum.com/threads/pictures-of-03-06-hard-top.29699/
The saga continues.
For anyone interested and/or any onlookers for the years to come, I'm slowly narrowing this problem down.
I finally got out with it and took some measurements. I've also come across maybe 4-5 others complaining of this problem. The most interesting one was from forum post made in 2007, with a nearly new TJ that he took back to the dealership for the problem. The consensus from all replies with "fixes" that have worked for some to fix the seal pinching problem, was to make adjustments to the doors.
My issue with gaps between the tops of the doors and hardtop is looking better, but still needs work. As for the seal, that's another story. As you can see in the last picture, the seal is still being pinched badly, but I don't have much room to go forward with the door. If I remember right, my door is now maxed out on the hinges with the distance that it can be moved forward, and it can't go much further forward due to the seal between the door and the windshield.
The saga continues.
