I have not used weldable primer before and several of my spring projects need it (I think).
I have read that the primer should be applied to steel after removing the rust and wiping it relatively clean of grinding residue (nowhere that I have looked indicated steel required a wipe down with acetone, brake cleaner or similar) and that prior to welding the primer should ideally be removed from the direct area to be welded (applies to the MIG process I will be using, other processes may not require scraping or grinding the primer from the directly welded area).
First question: Do the directions above match the process that is normally used with success? It would be nice to weld through the primer and not have to grind the areas to be welded but I certainly will if this will effect the weld.
Second question: Does the brand of weldable primer matter too much or will any zinc based etching primer work (assuming it is advertised as a weld through primer)? If the brand matters what brands have you used with success?
