What are the pros and cons of running a locker in your daily? I was looking into a USA Standard Spartan Locker for Dana 30 Differential. I've never run anything like this so any info would be great.
That front mounted automatic lunchbox locker would be fine until you need to engage 4x4 during your New England winters after they cover the streets with snow and ice. At that point it would cause steering issues. I'd go strictly with a selectable locker if I had to drive on icy or snow covered streets much. A selectable locker means you can lock or unlock it by a switch or lever as conditions dictate.What are the pros and cons of running a locker in your daily? I was looking into a USA Standard Spartan Locker for Dana 30 Differential. I've never run anything like this so any info would be great.
The Spartan will click in a Dana 30 when you turn. It is something people typically get used to. If you get a PowerTrax No Slip, it will cost about $150 more, but will not click. If you drive on snow and ice in 4wd it will cause understeer. A selectable woudl be a better choice in those environments. Otherwise, there are no cons. As far as pros, they are a locker, enough said.What are the pros and cons of running a locker in your daily? I was looking into a USA Standard Spartan Locker for Dana 30 Differential. I've never run anything like this so any info would be great.
FYI, I've been fine with my Lunchbox up front around here so far. The biggest issues I've had are when I've got my rear locker on too and it pushes me. Some of the offroad trails are near edges, you know what I'm talking about. It can be a little sketchy at times.I've been reading that a lunchbox locker like the Spartan will make the Jeep drive really wild when your on ice, snow or slick roads.
As you can see above, most guys will tell you to get an e_locker of some kind if you drive snowy or icy roads at all.
