This post is a quest for knowledge, as much as it is about getting the ride I want. I've spent a significant amount of time reading through threads on everything from tire pressure, tire load rating, springs, shocks, control arms, weight, etc. Although I've seen bits and pieces, finding a compiled list of items, that when done, have an effect (see definition below) ride quality, and what doesn't, is difficult. Especially, given the way threads tend to devolve. I even read through this thread, which gave some information, with one item (Tire Load Rating) conflicting with other information.
https://wranglertjforum.com/threads/how-can-i-fix-a-harsh-ride-on-my-jeep-wrangler-tj.16558/
That said, the goal here is to put together a concise list that I'll update in the original post. Although I don't expect to get it right up front, I'm confident you all will ultimately help define/refine it. Perhaps, later, this could be appended to the list Chris started. For further clarity, we're talking about the "effect" of changes made, i.e. the noun
Lastly, we should differentiate between two particular topics. For the purposes of this thread, the latter, "quality" is our focus here. Specifically, the "standard" that should be measured against is a new (let's say broken in) stock Jeep. With that in mind, anything we do to them should at least maintain the stock level of ride "quality" or, preferably, improve it. To be clear, I'm not saying the factory ride was ideal, but that a reference is needed.
1. com·fort [ˈkəmfərt]
NOUN
a state of physical ease and freedom from pain or constraint:
"room for four people to travel in comfort"
2. qual·i·ty [ˈkwälədē]
NOUN
the standard of something as measured against other things of a similar kind; the degree of excellence of something:
"an improvement in product quality" ·
Lets start the list!
(Insert word/s below) has no effect on ride quality: Example - "A spring change has no effect on ride quality."
- A spring change (Assuming springs made for this platform are fairly close in rates)
- A control arm/joint
- The arm angles (Up to 5" lift)
- The tire load rating
- The wheel size (Assuming wheels in the 15" to 17" range)
(Insert word/s below) has an effect on ride quality: Example - "Road surface conditions has no effect on ride quality."
- Shocks, shocks, shocks
- Road surface conditions
- Tire pressure
- Tire balancing
- Sprung weight (Assuming shocks aren't adjusted accordingly)
- Un-sprung weight
’Effect’ as a Noun
As a noun, an effect is "a change that results when something is done or happens," or "a particular feeling or mood created by something."Lastly, we should differentiate between two particular topics. For the purposes of this thread, the latter, "quality" is our focus here. Specifically, the "standard" that should be measured against is a new (let's say broken in) stock Jeep. With that in mind, anything we do to them should at least maintain the stock level of ride "quality" or, preferably, improve it. To be clear, I'm not saying the factory ride was ideal, but that a reference is needed.
NOUN
NOUN
- Tire pressure
- Tire balancing
- Un-sprung weight
