A master plumber showed me this nifty product: https://www.amazon.com/dp/B00ZWMVKPA/?tag=wranglerorg-20
That will go up to about half an inch in bolt diameter. I imagine the side step bolts aren't nearly that big?
As for tools, take a look at Rigid, Klein, SK, Channel Lock, Knipex! They are pricey, but in the long run will save you money! (just wanted to throw that out there!)
Damn, I've been a plumber for 20 years and never knew this existed. I lost track of how many times I've fought those damn Johni-bolts. I just added this to my Amazon wish list! Most tools like these are made by someone in the trade and do not get much mainstream attention. Thanks!
Reactions: Kyle_W
It's insane how much corrosion and paint can tighten up a bolt. That's why I buy snap on bits though. I break so many and they send new ones (the only snap on thing I can afford) LOL.
Don't blame you there!
Damn, 2 snap on bits. I guess I won't even attempt it with what I got. Lol
I didn't heat or use oil like I should have though. It sat out in the summer heat for a good day though ha. To be 100% honest. I do not notice a HUGE difference in quality over snap on as all my tools in the past usually get the job done (unless you want to remove the rear upper shock bolts). The real selling point for me is my local salesperson and he will replace worn or broken bits without blinking an eye.
Reactions: IronCity
Good!
I'm assuming you've used Rigid's "One Stop Wrench"? If not, that's another tool you'd love!
If you want a set of screwdrivers that you'll have forever, then go with these: https://www.amazon.com/dp/B0096PFTEW/?tag=wranglerorg-20
Do you have any idea how many free sets of harbor freight screw drivers I could buy for the price of those?!? Lol
I did install new shocks on my rear glass today... no more glass hitting me in the head when I reach in the back!
1997-2006 Jeep Wrangler Shocks - Rear Glass WINDOW Hatch - Gas Charged Lift Supports (Pair / 2pc) https://www.amazon.com/dp/B00Z2CXFLW/?tag=wranglerorg-20
Haha trust me I know what you mean. My Grandpa, who shops there almost religiously since he already has all his quality American tools, has 10+ of their magnetic bolt dishes, small flashlights, screwdriver sets, and multi-meters!
Took it out in the snow with muddies for the first time. Talk about slick. Aired down to 20psi and gained back the lost traction. It's all good.
Reactions: Kyle_W and Chris
I got the Eastwood stuff in the frame, finally. I am pleased with the coverage. I will see how long it takes to firm up and cure, since it was 75º out when I did the frame degrease and final washout. It fully dried internally and we sprayed in the Eastwood stuff and it had enough time to become touchable before the cold came back that night. It has stayed around freezing since then, so It is not curing. It will this coming week, though, so no worries.
I still have to do an inspection with the endoscope and mark the frame wherever there are areas that got poor coverage. (I think there are three in one rail and two in the other.) Then I will touch up just those areas.
We still have to do the body mount torque boxes. They have been degreased and sprayed out really well, but they were not drying out as well as the frame. Once it warms up again I will do those in the Eastwood black so that I can see coverage. (The green in the black frame worked very well in this regard.)
Yesterday I finally bought the Black Magic Brakes Dana 44 Disc Conversion Kit. I am stoked about that one for sure. I know there will be no gain in power due to the proportioning valve, and I fully agree with why they do that. However, I *despise* working on drum brakes, so this will be a welcomed upgrade when we re-gear.
One plus for this kit is that my old drums still have a lot of shoe material left, and that is because they are so rusted up that they do not appear to work very well. And my parking brake shoes are gone. My parking brake just barely holds the vehicle still on a flat surface. I calculated the cost to me for a complete rear drum brake replacement/rebuild. Blaine's disc conversion kit is only about $150 more, so why not?
Since photos are king in a thread like this one, here is one of one of the tool access holes in my frame clearly showing what sort of coverage you get when you can degrease and pressure wash 100% of the inside of the frame rails. It looks like this all through the frame...
Reactions: dylansalrin
@Wade, you'll love having rear discs. It just makes things so much simpler to work on!
Damn... Your frame looks very, very clean inside. So that's after pressure washing it?
Reactions: Wade
Yep.
First we blew the rails out as best we could using my homemade "TJ Frame Blow-Out Air Gun" and then I drilled my holes and de-burred them. After that we ran about a liter of pre-mixed degreaser through the pressure washer with a soap tip to make it foamy. It seemed to really get the degreaser into all the cracks and crevices, including in the slightly rusted areas. I let that sit for about 15 minutes. (you should not allow the degreaser to dry on the metal for some reason.) Then we used the excellent Clog Hog through the access holes I drilled for it. We used the version called the Needle Nose that is only 25' long and that has a shorter and more narrow tip. I found that a 5/8" hole allows this thing to easily enter the frame rail through the rear crossmember "cap" the bumper mounts to. We ended up running it from the rear to the front and back about three times to get all the degreaser out and to blow out any remaining rust chips, scale and pebbles. We then used the homemade frame air gun again to blow out as much of the standing water as we could remove.
We then let the frame dry in that nice, 70º weather we were having the other day.
After about two hours we came out and used the endoscope to look for water. We saw none. So we blew it out again to be safe and then taped off every single hole in the frame on all four faces of each rail. (The Eastwood runs badly and the overspray is nasty, sticky stuff. I wanted this to be as clean as I could get it on the first shot.) After the taping we opened up each hole we wanted to use one at a time and applied the Eastwood Internal Frame Coating.
[Frame drain hole proof-of-concept: When we finished and unmasked everything the Eastwood POURED out of the holes next to all the LCA brackets as well as the ones I had added to the very ends of each rail. POURED.]
We used three cans and all of it stayed in the rails including the fumes for about a half an hour, so the bottom face of each rail received a huge amount of this stuff. I am guessing it will take all of the rest of January and some of February to fully harden and cure due to the cold. We shall see about that over time.
Anyway, the rails received what looks to be a very heavy coating with even coverage and pretty darn good adhesion due to the use of the degreaser.
Being able to fully access the insides of the rails made all this possible. It's amazing what you can do to help your frame when you decide to correct Jeep's oversight and add in those drain holes *and* you add those two 5/8" access holes in the end cap crossmember. Amazing. It just becomes so much more easy to figure out how to address the rust and filth.
I am guessing you could further spray in Fluid Film using the Eastwood 24" spray hoses. I used only one for my three cans, so I have two left. I will have to see if they can be used on my cans of Kroil, PB Blaster, Fluid Film, and other stuff like that. Eastwood sells just the hoses for like $8 each. Handy things to have, to be sure.
