As usual with these Jeeps, that solution leads to other potential problems. They can mess with the available shock travel which matters if you are keeping an eye on their up/down bias. They also can create clearance issues with the exhaust too. Rather than introduce other variables, I also opted to notch the spring perches.
You're not wrong by any means, but there's always a trade off.
Reactions: Jeep 541X
Yes. If you rotated your pinion up for a CV rear driveshaft, you rotated your shock mounts down (and closer to the rocks). Which now further extended your rear shocks, and now limits your available down/extension travel. And brings your shock body closer to the rear axle tube. That's why folks use these brackets. I originally used the Tera-Flex brackets when I did my Jeep's suspension.
One day I crunched the driver's side rear lower shock mount on a rock. So we cut the rear lower shock mounts off, and welded on new ones that positioned the shock mount up higher (almost level with the bottom of the axle tube). Now my shocks were more compressed, and I had very little upward movement before they were fully compressed. So replacement shocks were in order. Even though my Jeep has essentially a 4" lift, I have to pay attention to the extended/compressed measurements of the rear shock before I buy them. I recently replaced my Bilstein 5100 series shocks with Rancho RS5000X shocks, and the rears are for a TJ with a 2.5" lift.
There's always a trade-off.
Installing the harness I made for my transmission swap.
How did the ride change with the new shocks? I have bilsteins and they're quite firm
I need to find someone that has Ranchos to ride with. My first shocks were RC- enough said. Now I have the 5100’s and think they ride real well! Could be that whole comparison between the 2 😂
:mad: And now I am asking myself, is this the next part I need to order??!!
:ROFLMAO:
Maybe a little better. I'm running stiff RE springs, and heavy tires (MT Baja Boss AT that are E-rated with 3 ply sidewalks). I thought I'd try the RS5000X since folks were saying good things and I knew my ride could be improved on.
Reactions: srimes
I was very disappointed when those shocks did little to improve my ride with 3.5” RE springs.
I then tried Fox which were too stiff to be likable. I then got Rancho 9000x adjustable shocks (set at 3/2) that rode “slightly” better than the 5000x. I have 15” wheels and c load rated STT Pros @ 25 psi.
I then went to Currie springs and that made a “slight” improvement (surprisingly noticeable but far short from being a legit improvement).
Bottom line (my opinion), is that my Jeep will still ride like a meat wagon until Blaine outboards my rig with 11”/12” Wayne tuned fox smooth bodies. I took one ride in Chris’s Jeep and it saved/ruined me on this topic.
I wish I could pay for everyone to get that mod bc it’s flat out amazing.
