I drive around on tires .... spelled T I R E S not Ta-wires , learn to spell this is Merica !
Not some limey prissy boon doggle !
Don't worry John I'm Politically Correct .......I'm an equal opportunity offender !
Thats some good craic.
Has anyone tried a set of cheap seat warmers? I had a gift card so I ordered this one off Amazon.
Mine came from amazon and were pretty cheap. I think mine was Watercarbon brand or something like that. Only issue I've had is one switch quit working. got another switch just like it from amazon and swapped it out.
How long have you ran yours?
10/14/2021 | Purchase |
10/14/2021 | TVAT, Title, Registration |
10/15/2021 | New seatbelts |
10/16/2021 | Dome and footwell LED |
10/17/2021 | spark plugs, side sill covers, stub antenna, feeler gauge, shift knob |
10/18/2021 | PP Inspection |
10/18/2021 | Emissions |
10/18/2021 | wire loom, grommets, zip ties |
10/18/2021 | laptop storage case and cable lock |
10/19/2021 | Shield ignition cable |
10/19/2021 | HAVC knob |
10/20/2021 | Dash Mount |
10/20/2021 | Rust reformer floor pans |
10/20/2021 | Paint back bumper |
10/20/2021 | Sell old winch and bumper |
10/20/2021 | Tow Hooks |
10/20/2021 | PS cap |
10/20/2021 | Stant Rad Cap |
10/20/2021 | Sell PO tube half doors |
10/21/2021 | HVAC and DASH Led |
10/22/2021 | 6ton jack stands |
10/23/2021 | Slider window springs |
10/23/2021 | PS fluid and leak stop |
10/23/2021 | fog light wiring harness |
10/24/2021 | BMB pads and rotors |
10/24/2021 | bumper bolts |
10/27/2021 | 2in Spring and shocks (procomp and Rancho) |
11/1/2021 | Self Oil Change - O'Riley High Mileage Conventional WIX filter |
11/1/2021 | 11mm Deep Impact Socket |
11/10/2021 | Labor for coolant flush, install BMB pads and rotors + new calipers and hoses from DA |
11/11/2021 | Sold rear seatbelts |
11/11/2021 | Sold front seatbelts |
11/11/2021 | Used Dark Tan Bestop + Shipping |
11/11/2021 | 4 17x8 4x4.5 pro comp rims |
11/11/2021 | 5 285/70/17 BFG KO2 |
11/29/2021 | Kicker Front and Rear Speakers |
11/29/2021 | Amp wiring kit |
11/29/2021 | Sub wiring kit + RCA |
11/29/2021 | Floor Jack |
11/29/2021 | under hood light |
11/29/2021 | softop bow straps |
11/29/2021 | wire for fogs |
12/07/2021 | JVC Head Unit |
12/15/2021 | 1/2in Impact socket set |
12/15/2021 | 1/in breaker bar |
12/28/2021 | winch cover |
12/31/2021 | misc bulbs |
01/02/2022 | 1/4in tourq wrench |
01/03/2022 | wire brush wheels |
01/03/2022 | valve cover kit (gasket, grommets, PCV, etc..) |
01/05/2022 | new shock bolts, breaker pipe, new breaker bar |
01/06/2022 | Hella 80/100 Bulbs |
01/06/2022 | Toyota headlight kit |
01/07/2022 | fender flare kit |
01/07/2022 | ron gift card, perkins bday |
01/07/2022 | sold old bedrug & fender flares |
01/12/2022 | UV leak kit |
01/19/2022 | seat belt adjuster |
01/21/2022 | Fuel Pump |
01/30/2022 | Wheel Chocks |
01/30/2022 | bag for rain cover |
01/30/2022 | backup camera |
02/07/2022 | hitch wiring kit |
02/07/2022 | Torx Security Set |
02/07/2022 | Forectec, mount, balance wheels, alignment, replace rear stud |
02/07/2022 | Spare rim |
02/16/2022 | Redline MTL- change trans fluid |
02/23/2022 | Crank Case Vent Hose |
02/23/2022 | bolt pen, fluid pump, polish pads |
03/07/2022 | MORE 1in body lift |
03/07/2022 | Dewalt Impact Wrench |
03/08/2022 | Impact Extensions |
03/08/2022 | Viair 88p |
03/08/2022 | Spare Fuses |
03/15/2022 | Bartact Lumbar |
05/05/2022 | Oil change |
06/05/2022 | Tcase fluid change |
04/28/2022 | Sound pods |
04/28/2022 | 3rd taillight riser |
05/03/2022 | Luk slave/master cylinder |
07/14/2022 | Redhead Steering Gearbox |
07/14/2022 | 1/2in Tourq Wrench |
07/14/2022 | MOOG ES3096L Tie Rod End |
09/16/2022 | DIY 5 tire rotation |
9/30/2022 | Labor for RH gearbox swap and fan clutch install |
09/26/2022 | Fan Clutch |
10/03/2022 | WRG ST Fairlead, Thimble, and Shackles. |
10/11/2022 | Thermocure and Coolant |
10/18/2022 | Thermostat housing, gasket, and tstat, scrapper supplies |
10/18/2022 | Sold Bartact Lumbar |
Hit the 1 year mark on my TJ and I’ve tracked everything I’ve done.
Started at 33,250
10/14/2021 Purchase 10/14/2021 TVAT, Title, Registration 10/15/2021 New seatbelts 10/16/2021 Dome and footwell LED 10/17/2021 spark plugs, side sill covers, stub antenna, feeler gauge, shift knob 10/18/2021 PP Inspection 10/18/2021 Emissions 10/18/2021 wire loom, grommets, zip ties 10/18/2021 laptop storage case and cable lock 10/19/2021 Shield ignition cable 10/19/2021 HAVC knob 10/20/2021 Dash Mount 10/20/2021 Rust reformer floor pans 10/20/2021 Paint back bumper 10/20/2021 Sell old winch and bumper 10/20/2021 Tow Hooks 10/20/2021 PS cap 10/20/2021 Stant Rad Cap 10/20/2021 Sell PO tube half doors 10/21/2021 HVAC and DASH Led 10/22/2021 6ton jack stands 10/23/2021 Slider window springs 10/23/2021 PS fluid and leak stop 10/23/2021 fog light wiring harness 10/24/2021 BMB pads and rotors 10/24/2021 bumper bolts 10/27/2021 2in Spring and shocks (procomp and Rancho) 11/1/2021 Self Oil Change - O'Riley High Mileage Conventional WIX filter 11/1/2021 11mm Deep Impact Socket 11/10/2021 Labor for coolant flush, install BMB pads and rotors + new calipers and hoses from DA 11/11/2021 Sold rear seatbelts 11/11/2021 Sold front seatbelts 11/11/2021 Used Dark Tan Bestop + Shipping 11/11/2021 4 17x8 4x4.5 pro comp rims 11/11/2021 5 285/70/17 BFG KO2 11/29/2021 Kicker Front and Rear Speakers 11/29/2021 Amp wiring kit 11/29/2021 Sub wiring kit + RCA 11/29/2021 Floor Jack 11/29/2021 under hood light 11/29/2021 softop bow straps 11/29/2021 wire for fogs 12/07/2021 JVC Head Unit 12/15/2021 1/2in Impact socket set 12/15/2021 1/in breaker bar 12/28/2021 winch cover 12/31/2021 misc bulbs 01/02/2022 1/4in tourq wrench 01/03/2022 wire brush wheels 01/03/2022 valve cover kit (gasket, grommets, PCV, etc..) 01/05/2022 new shock bolts, breaker pipe, new breaker bar 01/06/2022 Hella 80/100 Bulbs 01/06/2022 Toyota headlight kit 01/07/2022 fender flare kit 01/07/2022 ron gift card, perkins bday 01/07/2022 sold old bedrug & fender flares 01/12/2022 UV leak kit 01/19/2022 seat belt adjuster 01/21/2022 Fuel Pump 01/30/2022 Wheel Chocks 01/30/2022 bag for rain cover 01/30/2022 backup camera 02/07/2022 hitch wiring kit 02/07/2022 Torx Security Set 02/07/2022 Forectec, mount, balance wheels, alignment, replace rear stud 02/07/2022 Spare rim 02/16/2022 Redline MTL- change trans fluid 02/23/2022 Crank Case Vent Hose 02/23/2022 bolt pen, fluid pump, polish pads 03/07/2022 MORE 1in body lift 03/07/2022 Dewalt Impact Wrench 03/08/2022 Impact Extensions 03/08/2022 Viair 88p 03/08/2022 Spare Fuses 03/15/2022 Bartact Lumbar 05/05/2022 Oil change 06/05/2022 Tcase fluid change 04/28/2022 Sound pods 04/28/2022 3rd taillight riser 05/03/2022 Luk slave/master cylinder 07/14/2022 Redhead Steering Gearbox 07/14/2022 1/2in Tourq Wrench 07/14/2022 MOOG ES3096L Tie Rod End 09/16/2022 DIY 5 tire rotation 9/30/2022 Labor for RH gearbox swap and fan clutch install 09/26/2022 Fan Clutch 10/03/2022 WRG ST Fairlead, Thimble, and Shackles. 10/11/2022 Thermocure and Coolant 10/18/2022 Thermostat housing, gasket, and tstat, scrapper supplies 10/18/2022 Sold Bartact Lumbar
Currently 35,760
And thanks to the people on this site, I’ve been able todo 95% of the work myself.
R.I.P that OG bumper.
What’s crazy is I was able to sell it to someone in FB.
Yeah I'm always craicing off , I guess it's the Irish in me ! LOL !
Slainte!
Devised a keyless console latch and modded the plunger-
Was missing the cylinder and latch -
Amazoned it.
I use my under seat box for valuables.
