New speakers, the little Kicker sub, and an amp. Made a plate to mount the amp under the driver seat.
trying to see if i have a good path to move up to the 2" receiver, raise the hitch up, look decent, and of course be strong enough for the task of towing a small utility trailer
new wiper blades and then addressed relocating the washer fluid tank. thinking about moving the air intake driver side. washer tank tucked up nicely up near the master cylinder.
I have a decent one, but it's just getting harder for these guys to help even if they want to. What part of the state are you in? I'm in south central, Southbridge area.
Installing the Bedrug into the TJ.. this stuff is cut to perfection and fits so nice!!
I’m out by Framingham. You must be able to get out to 508 Intl quite a bit being based out of the Southbridge area.
What did you use for caps?
No old crutches available...What!?
You paid over $13 for that?
The OLD Zorba would have stolen 2 pens from the bank and then taken the caps off of a pair of old crutches and done this for zero.
What's going on down there? You hit the lottery?
I'm on the N Oxford, Charlton line and there are a couple around here that seem to be ok.
Which TJ???? The TJUR or the TJ????
Looks like that would get in the way of putting fluid in the clutch master cylinder .
Time to get it dirty.
You are right around the corner from me. Maybe you know Mike's in Charlton? Mike died about a year ago, but his son still runs the place. He does what he can. Nice kid.
Found snow. Got stuck. Got unstuck. Broke shit.
Junkyard alternator lasted about 25 days. Check engine light is from random misfire codes. Brakes got soft...gotta check that switch in the proportioning valve... guessing I should have had a brake light too.
Drove for an hour or so on my Optima deep cycle yellow top and battery was still at 12.88 when I got home.
-Mac
