Replaced this grenade. The wear is more substantial than I expected given just recently hearing a slight “tick” and feeling it on the OPDA.
Glad that’s wrapped up.
In my experience no. Are you positive the key is turned to the off position? Some keys, included my own, will come out even when the key is not fully in the off position. Also, if you are going completely back you may inadvertently be putting it in accessory mode.Just a question? Is it normal for the windshield wipers to work with the ignition off? Not even a key inserted. 2006 TJ.
. Thanks! I had the switch in accessory instead of off! Figured it out now. The switch is kind of worn so it’s a little hard to feel the clicks! Thanks again!In my experience no. Are you positive the key is turned to the off position? Some keys, included my own, will come out even when the key is not fully in the off position. Also, if you are going completely back you may inadvertently be putting it in accessory mode.
Holy wire nuts batman!!!!!Dismantled the dash and and doors.
Get to replace the AC / heater panel! Arizona dust......lovely stuff!
Oh yes!Holy wire nuts batman!!!!!
Sence you have it off. Now is the time for soldering and shrink tube.
noJust a question? Is it normal for the windshield wipers to work with the ignition off? Not even a key inserted. 2006 TJ.
Your power is probably the alternator. For the tractor sound, do you know how to seafoam your rig?
Willys have you tried a real good set of channel locks or vice grips? I did the same thing on my wife's van and a set of vice trips was able to grab it enough to turn it. I also used a propane torch for some heat on it.Got 3 of the 4 o2 sensors replace which got the CEL to go out. And I got the Kenwood head unit in and working, but still have to go through the settings. Dropping the front driveshaft gave me enough room to replace the sensors from underneath the Jeep. I wasn't about to try it from above.
Unfortunately, I couldn't get the 4th sensor to break loose and rounded off the flats trying to get it to budge. I put enough pressure on it to bend the exhaust over about 3/4 of an inch. Fortunately, it sprang back into place when I quit pulling in the breaker bar. I'm thinking it's going to stay there until I can get it to a muffler shop and let them deal with it.
