For an even better upgrade you can plug an led for the halogen!GM Under Hood Light
This was a genius idea, thanks to all!
- Soldered
- Heat shrunk
- Wire loomed
- LED Bulb
- Soldered
- Heat shrunk
- Wire loomed
- LED Bulb
Very nice indeed! Love the welded frames for the "artwork" in the second-to-last pick.And for those asking about the other "artwork" in the shop, here it is...
Nothing too bad. Just not a sound i would ever like to hear again lol!SUCK! No damage, I hope.![]()
Got my dash put back in along with the steering column and ignition!!!
My cooling system (mopar rad and water pump along with everything else) and new AC parts should be coming tomorrow, so hopefully I can get everything installed and fire up the rebuilt engine for the first time next week! Exciting times.
The later model factory skids still fit the early model TJs. I have a 2000 and it came with the open sided skid like the one that came off your jeep. The newer design is much better constructed IMO.
Here's the one I put in after replacing the pump
This is the one that came factory with the tank still in it (same as the one on your Jeep)
The cover does look good on there, I didn't want to remove mine either. So I trimmed it some when I put my winch on and was able to keep the cover on, don't even notice where it was trimmed. I can take a picture of the winch on and cover on if you like. It does look alot cleaner with the cover.I, personally, like the stock-ish look of the Jeep, hhnce why I have no plans to lift the Jeep. Similarly, I like the way the cover looks right now.
Just been on and off on deciding to get a winch, seeing if there's any way to add one without cutting that cover.
Thanks, though!
Got a link?Today was just rain here, hail was last week.
Bought a 10'x12' rain fly for a hammock (but not for a hammock) a couple of weeks ago, rolls up to the size of a loaf of bread...and has a Jeep wave built in.
Dry as a bone.
One thing, it is not perfectly square, more like diamond shaped, add a couple of tent poles and you have a tailgate party.Got a link?
What did you use to paint the dash?Got my dash put back in along with the steering column and ignition!!!
Lol the skid was horrible I've only had the jeep for a bit so rust was the first thing I went for knowing the issues with these TJs..no rot through the frame or cracks or holes..rear driver side is the worst of it inside the frame..cleaned it out as best I can drilled some drain holes and coated inside with Eastwood's..hoping for the best.but yea that tank skid was a nightmare to behold..gave the new one a light coat of oilHello fellow sufferer, apparently I'm not alone with the rust problem![]()
SEM color coat. Graphite and flame red.What did you use to paint the dash?
