Realized that I have two bolt holes in the back that go all the way through. Does anyone know what I need to plug these holes?
Can you show a broader picture, showing a larger areaRealized that I have two bolt holes in the back that go all the way through. Does anyone know what I need to plug these holes?
View attachment 236092View attachment 236093
Thanks, it’s not easy to represent the true location. I hope this picture works out. I took it from the back looking forward. No back seat.I would say seat belt bolts for rear seat.
But that picture is a bit close
Seat belt bolts would make sense. Does this picture help?I would say seat belt bolts for rear seat.
No back seat?, so no seat belt dangling from the roll bar?Thanks, it’s not easy to represent the true location. I hope this picture works out. I took it from the back looking forward. No back seat.
No back seat or any hardware for it. To plug, are there bolts I can order?No back seat?, so no seat belt dangling from the roll bar?
The spot welds around the hole are reinforcement for the seat belt mount.
Just put some plugs in there. Would look better than a bolt...cheaper and less hassle.You can get creative and stop at the hardware store for a couple of black plastic plugs. That way you won’t have a bolt head and it would blend in better.
If that’s the route to go then just some black RTV and call it a day.bathtub caulk and a black magic marker?
Determine the size and thread pitch; install a threaded plug with teflon tape around the threads. You should be able to locate what you need from Ababa Bolt. Mc Faddendales or a similar hardware store.To plug, are there bolts I can order?
ay, if you don't have to run get it and it's easy enough to tear out if you ever need the hole again, why not?If that’s the route to go then just some black pvc and call it a day.
Perfect, thank youCheapest and easiest route will be to go to a hardware store and find some that fit. Or find a plastic plug.
Thank youDetermine the size and thread pitch; install a threaded plug with teflon tape around the threads. You should be able to locate what you need from Ababa Bolt. Mc Faddendales or a similar hardware store.
PVC ???If that’s the route to go then just some black pvc and call it a day.
