What do I need to plug these holes?
Idaho Jeeping Girl
Idaho
Realized that I have two bolt holes in the back that go all the way through. Does anyone know what I need to plug these holes?
Some stainless bolts or black plastic plugs at your local ACE Hardware would do the trick.
Cheapest and easiest route will be to go to a hardware store and find some that fit. Or find a plastic plug.
Plastic plugs are cheapest and should work fine.
Heck, I put foam ear plugs in mine to keep the bedliner I was spraying on from getting in the threads. It was at least a year later before I realized they were still there and put the bolts back in.
No back seat or any hardware for it. To plug, are there bolts I can order?
You can get creative and stop at the hardware store for a couple of black plastic plugs. That way you won’t have a bolt head and it would blend in better.
Just put some plugs in there. Would look better than a bolt...cheaper and less hassle.
I personally would just get a bolt that fits and put it in. Jeep the threads safe in case you want to use them in the future.
