I just bought 1 ton axles for my 99 jeep tj. Just wondering if anyone had any issues installing them and any special parts I need to get.
Just a heads up, that's a "7/8-ton" front axle... Ford used D50's from 1999-2002 on everything SRW. They aren't bad axles and I've seen a handful hold up to some abuse on XJ's, but they have limited aftermarket support.
With that, as Blaine said, you'll need to trim the spring perch on the driver's side. Generally, most people trim back about 2" and then smooth over the remainder of the mount with some grinders and flap disks.
And the 50 doesn’t have the same options as a 60, less lockers or gears…
Let's cut to the chase, what size tires do you want to run?I have dana 44s front and rear should I just build them up and sell the heavy axles?
