hey gang, i gotta change out my fuel pump soon and was curious to know if anyone had had any good experiences with cheap amazon/ebay sub $100 fuel pump assemblies, or should i just spend $200+ and go to o'rielies with that replacement warranty?
Delphi has been performing pretty well thru the community and has generally become one of the "Go To" assemblies, mine is going on 7 years without issue. What problems did you experience..Bosch, no Delphi or Airtex or no-name brands unless you want to do it again in a few months.
Dead pump about 3 months after install.Delphi has been performing pretty well thru the community and has generally become one of the "Go To" assemblies, mine is going on 7 years without issue. What problems did you experience..
Seems to be on the rare side for them, at least I hope.Dead pump about 3 months after install.
That will do the job. It’s not difficult. The hardest part is dropping the tank/skid…i cant seem to find a whole bosch assembly. Is it hard to just add standalone pump to the assembly?
like this one:
https://www.amazon.com/dp/B000BZL922/?tag=wranglerorg-20
i out in a delphi and it was a dud. took forever to crank and i removed the gas line to see if it was squirting and sure enough it was super intermittent... now perhaps my crank sensor is gone too? but im gonna put on a new replacement delphi tomorrow and hope for the bestDead pump about 3 months after install.
https://www.underhoodservice.com/fuel-pump-diagnostics-using-voltage-drops-and-current-draw/well back home and it looks like i'm only gettin 10.6v to the fuel pump, So would changing out my relay fix that?
