Question about tire diameter in actual use. 33/10.5/15 BFG KM3's are actually 32.5. Seems like most tires are at least a 1/2" smaller than their advertised diameter. That's not measured diameter but the numbers from
https://tiresize.com/calculator/ when you go to individual tire spec's. Measuring the diameter, makes them even shorter. When driving at 70mph does the centrifugal force on the rotating tire stretch them out to a figure closer to their nominal size or is the measured diameter more accurate?? Grim Jeeper's site allows you to input tire size to the second decimal so calculations vary from nominal tire size, to Tiresize diameter to measured diameter at rest.
In any case, it looks like 5.13 is the gear for 32" tires for the Dana 30 limited jeeps running a 4.0/42RLE. Even then you are only running 2600 rpm at 70.
