Bestop
With that out of the way, there is a reason Jeep chose Bestop as their OE supplier for the factory soft top. Bestop is simply put, the best-of-the-best when it comes to replacement soft tops. There is no better soft top out there in terms of quality than the Bestop soft tops.
Here's a list of the various Jeep Wrangler TJ soft top models offered by Bestop:
Bestop Supertop NX
The original Supertop Classic set the standard for replacement convertible Jeep soft tops, but Bestop wanted to make it even better. So we added our exclusive Sunrider flip-back panel, Top Arch bars and factory-style Door Surrounds to create a new generation - the Supertop NX. Ideal for those Wrangler owners that currently don't have a soft top, this is the solution to getting the most out of your Wrangler on the trail, or just around town.
Who is this top for?
This is for the Wrangler TJ owner who wants a factory top but doesn't have the factory hardware. This top comes with a replacement top, as well as OE quality factory hardware (door surrounds, bows, and everything else you need to install it).
Where can I buy this top?
Find the top you're looking for below and click the link. You'll then be able to purchase the top on Amazon if you'd like. Please note that I have done an extensive amount of research with these part numbers. If the Amazon product title says something different (i.e. a different color), do not pay attention to that. Only pay attention that the part number on the product on Amazon is identical to the one I've listed below.
Bestop Replace-a-Top
What if your original factory soft top hardware is in good condition, but the fabric and windows have definitely seen better days? Replace-a-top™ takes advantage of your still-good factory hardware, and gives you all new fabric and windows without having to replace your existing factory frames and hardware. It's one of our most economical ways to make your soft top look brand new again.
This top is for the Wrangler TJ owner who has an existing soft top, as well as all the factory soft top hardware, but simply needs to replace the top material. This top comes with a complete OE replacement soft top skin, minus the hardware.
1997-2002
51127-15 (Black Denim, Clear Windows)
51180-15 (Black Denim, Tinted Windows)
51127-33 (Dark Tan, Clear Windows)
51180-33 (Dark Tan, Tinted Windows)
51127-37 (Spice, Clear Windows)
51180-37 (Spice, Tinted Windows)
2003-2006
51178-35 (Black Denim, Clear Windows)
51193-35 (Black Diamond, Tinted Windows)
1997-2002 (Sailcloth)
79122-01 (Black Sailcloth, Clear Windows)
79139-01 (Black Sailcloth, Tinted Windows)
79122-37 (Spice Sailcloth, Clear Windows)
79139-37 (Spice Sailcloth, Tinted Windows)
2003-2006 (Sailcloth)
79125-35 (Black Sailcloth, Clear Windows)
79141-35 (Black Sailcloth, Tinted Windows)
All Years (Twill)
79841-17 (Black Twill, Tinted Windows)
LJ (Unlimited)
79140-35 (Black Sailcloth, Tinted Windows)
Bestop Trektop
Our original frameless Trektop Classic was a showstopper when it was first introduced back in 2008. It even won Chrysler's 2008 Design Excellence Award and is the forerunner to our best-selling Trektop NX. You don't need factory frames and bows so installation is quick and easy. Trektop Classic is a complete replacement soft top with fast-back styling at an economical price.
This top is for the Wrangler TJ owner who wants a bowless soft top. This soft top doesn't have any bows or hardware (other than door surrounds and a header seal), which makes installing and removing the top a breeze.
Bestop Trektop NX
We’ve covered all the angles. Bestop's innovative fastback styling has made Trektop NX the best selling soft top on the market today. Trektop NX is truly a complete soft top but doesn't need all the frame hardware and bows of traditional soft top designs. It takes advantage of the Wrangler's sport bars to give it shape and support for an easier installation. And there's an added bonus to the Trektop NX - just zip out the windows and it transforms into a Safari Bikini Top.
This top is for the Wrangler TJ owner who wants a bowless soft top. This soft top includes all the features of the Bestop Trektop, but also includes the ability to remove the side windows and rear window, and then function as a standalone safari top!
What is the "sailcloth" option?
Sailcloth is a step above the base material that Bestop tops are made of, but not as nice as the twill. It will be quieter, warmer, and a bit better than the base material.
What is the "twill" option?
The "twill" option is Bestop's highest quality material. The standard material that comes with all the Bestop tops is a vinyl type material. It's a little thinner than the twill, but I've used the base model top personally, and it is by no means bad. The higher end option is called "twill".
Twill is a huge upgrade and very much worth the price increase. The twill is thicker, quieter, absorbs much less dirt (which translates to being much easier to clean) and when compared side-by-side with the standard Bestop material, it's immediately obvious to see why it costs more. The twill will do a better job at keeping the heat in and keeping the cold out. It will also likely last longer due to it's extra durability.
What is the difference between "black denim" and "black diamond"?
From 1997-2002 the Jeep Wrangler TJ had a "black denim" soft top. This referred to the color of the soft top material which was black, but almost had a denim look to it (like a pair of black jeans).
From 2003-2006 the Jeep Wrangler TJ had a "black diamond" soft top. The soft top was identical to the earlier TJs with the exception of the soft top material being a much deeper black color.
Here's an image that shows a "black diamond" top on the left, and a "black denim" top on the right. These tops are 100% interchangeable, just order whichever one is the color you prefer.
