Currie is now RockJock. Google would probably get you to it but thought would be easier if pointed you in right direction.
As said, Currie or Savvy are gold standard but not cheap. This will give you an idea. https://www.rockjock4x4.com/CE-9801H
But that is only the starting point as will need shocks, SYE, and rear driveshaft. Possibly more.
Personally I would piece together a 2.5“ package with MML and BL for 33s but here is an idea of kit price. https://dpgoffroad.com/product/old-man-emu-ultimate-tj-lj-wrangler-kit/
You should be able to avoid SYE and rear driveshaft if you stay at 2.5”. May want them down road but reduces initial cost.
Here is an idea of piecing together the same ‘kit’.
OME 2934 front springs https://www.amazon.com/dp/B004P9JT40/?tag=wranglerorg-20
OME 2949 rear springs https://www.amazon.com/dp/B004P9M1FO/?tag=wranglerorg-20
Rancho RS5000X shocks https://www.amazon.com/dp/B01963N4ZY/?tag=wranglerorg-20
Savvy 1.25” BL https://savvyoffroad.com/product/sav-bltj/
BrownDog 1” MML https://browndogindustries.com/browndogindustries.com/Wrangler-TJ-40L-3.aspx
Currie front trac bar https://www.rockjock4x4.com/CE-9120TJS
Currie rear trac bar bracket https://www.rockjock4x4.com/CE-9121N
JKS rear sway bar link https://jksmfg.com/i-8938523-wrangl...le-sway-bar-end-link.html?ref=category:329567
That will put you around $1,300. I didn’t price shop any of the pieces so might be able to reduce that. Will still need bump stops and ideally sway bar disconnect for the front. That ranges from cheap options to the Currie Antirock https://www.rockjock4x4.com/CE-9900.
If you already have 3.73 you can live with that for a while before you regear. I ran 3.73/33s on my first TJ for couple years and am still managing with 3.73 and 35s on LJ while I collect parts/$ for regear. That would also give you time to wheel and decide if you are going to want lockers. Cheaper to do lockers and gears at same time if you can.
Installing the lift yourself isn’t horrible. Plus will give you chance to cycle suspension, see how it works, etc. If you are doing work that have body off then would be perfect time to do it.
Could probably go cheaper than say the JKS adjustable rear link but if you move to a 4” spring in future don’t have to replace. With BL and MML you are set up to do tummy tuck in future (I think where SYE and driveshaft would be needed). Really just trying to say makes sense to go with quality parts that can support future changes because once Jeep bug bites you may be ‘building’ it for life.
*Disclaimer - I’m by no means an expert. Am currently out of funds for more parts on my build list so is fun to spend your money
