Picked this up a couple weeks ago (trailer included). Not certain what to do.
Crank up the Molly Hatchet and do smokey burnouts.
I think we're a few hours and dollars away from that being possibleCrank up the Molly Hatchet and do smokey burnouts.![]()
I'd recommend a new tire.
Found the culprit:
Exhaust pushrod on the right rear cylinder.
Best guess is it filled with coolant and locked when I started it.
What's the problem? Looks right as rain; nothing to see here, move along!![]()
Found the culprit:
IDK on what to do with the (aluminum) heads accept take them to the machine shop and have them go thru the valves and check them for cracks and flatness....its been 35 years since my motorhead days of rebuilding small block chevys!
My 25y/o son goaded me into wrenching on this ourselves: "Come on dad remember all those engines you worked on when you were my age"
I for one will not crack jokes at your expense Greg. I won't quit on you.
I can crack jokes since I might be doing something similar soon...
The rolling joke for dodges is the transmission?
Tell you what i want to find a late 90's cummins to put in front of my k20's nv4500. Old school intercooled coal until fking california turns off the oil pumps!
@Farmergreg also important to get new upgraded bosch injectors.no substitutes.and stay away from ebay and industrial injection! Cheap isn't a good deal
No ebay deals for sure. GM certainly made the LB7 a complete bitch to do injector work on.
These are the injectors I was planning on, as they have the "shut off" point above the atomization point.
https://ssdiesel.com/ss-diesel-motorsport-sac00-lb7-duramax-injectors-now-available/
The sac00 was supposed to be great,then heard bad things about them. I went with bosch injectors. I wish I'd done sac45s and compound turbos when efi live was still a thing.but then I'd need a 20,000$ shortblock!
Do some more research on those before buying
What negatives have you heard?
That they aren't as long lived as they were supposed to be and have flow rates all over the place.
Lincoln diesel is my go to for parts and they won't carry them anymore..
[/URL]
Btw if you have the time its a good opportunity to port the stock elbow to the turbo and swap in a drivers side lml exhaust manifold.
I did grade c head gaskets and wish I'd saved the old ones and went with those thicknesses(each side can be different).but for how hard i push that poor motor i guess slightly lower compression is a good thing![]()
When I was surfing it looked like you could get new or reman on the injectors.
This going to be pricy for a guy that doesn’t have @Wildman kind of money!
