What rear axle comes factory on a 1998 TJ?
Ok I will do that in the morning. I think it may have been swapped and has lockers in it now. Don’t know a lot about it
Could be just about anything back there..8.8 even if it's been swapped..pics will tell for sure
The standard Dana 35's differential cover is perfectly oval with a snap-in black plastic lubricant fill hole plug. The significantly stronger optional upgrade Dana 44's differential cover is kinda shaped like a stop sign with a threaded steel plug in its lubricant fill hole.
Reactions: jeepguy03
