As @jjvw said you're paying for a lot more than just axles with a Rubicon.Thanks for the input guys. I really appreciate it. Would I avoid having to upgrade the axles if I buy a Rubicon trim TJ from 2003-2006? I’m definitely going to buy one down south or out west. What frame procreation would you recommend when I eventually get the Jeep? Thanks in advance !
With a standard TJ if you want to run 35 inch tires, you're going to have to upgrade or replace the rear Dana 35 axle with something stronger. However, 33 inch tires should be fine as long as you don't beat on it too hard.
