So currently I am on a 4in lift, 2in deep ucf skid, sye and savvy rear uppers. Front currie track bar and currie steering but rear track bar is stock with a non angled raised bracket on the axle side and all other control arms are (both lower and front upper are stock) I do hope to mid arm but bc I’m still in college it would take me a very long time to save enough to buy or even build a mid arm, as well as I have no welder or place to install the mid arm as I’m currently doing an axle swap In a parking lot.
I still would like to get a sway loc and other things but I’m on the fence if I should try and budget in the rest of the control arms and a rear trac bar( 1,800 ish but bolts in) or spend the money on other things I won’t swap out such as a sway loc and wait till I’m out of college to mid arm and no have to worry about re doing things?
I get most of my travel but with 10.75 travel front and 9.5 rear my down travel for both front and rear are limited with about 1.5in left of shock shaft. It’s all from the rubber bushings bindings. I’d like to outboard too and from bfh video on the red lj with short arms ( I know both of them are on the forum but I can’t remember who’s lj that was) he didn’t have problems getting 12in travel out of good miss alignment joints. Should I wait for mid arm and outboard at the same time ( and getting currie coils bc currently I have metalcloak 3.5in coils) to set it all up properly?
