Where does this dashboard connector go?
kootenay1025
cranbrook bc canada
i have a 1997 jeep wrangler with 2.5 litre engine , i relaced the heater core , which went well but now my dash lights , fog lights , and toggle switches do not light up . everything else works . i have one conector that does not have a home . it has a orange and brown wire going into it . is this my problem ?
Probably missed the grounds...left and right speaker covers and check the big one on the firewall between the battery and the engine.
If your marker lights are working check fuse 12 behind the glove box. That supplies all of the dimmable lights on the dash.
If the marker lights are also out, check fuse 1 behind the glove box.
Welcome to the forum. Let us know what you find out.
Also see the 2.5 thread and 97 thread in my signature and let us know if you have anything to add.
well taking another run at it today . I have this plug without a home . Any ideas on where this belongs ? Is this my problem ?
I put my meter on the grounds on the plugs , they checked out . Is there safe way to check the cluster ? Should I replace the bulbs ?
The cluster and dash illumination wire is fed from fuse 12. The wire is orange in colour. The wire can be checked anywhere that there is illumination on the dash. HVAC illumination, fog lamp, rear defog and rear wiper switches, radio, auto selector bulb (connector is probably there even on manuals). And also at the cluster connector.
If all except the cluster is illuminated, then the issue is most likely a bad connection at the cluster connector.
If all dash lighting is out, there is no feed from fuse 12.
If the marker lights illuminate, there is power to the light switch. The output from the light switch to fuse 12 is a variable voltage. I'm not sure what the voltage output range is but I'd presume it's something like 6-12V.
