Which bump stops?
GreenTJ
I Break Stuff
Ladysmith, VA, United States
looking for a set of bump stops and have narrowed it down to these 3 options, if anyone is running any of them i would love to get your opinions,they all mount via pinch can as i dont have the option to run brands like tera, jks or RK that mount to factory locations,im leaning towards FOA just because of pricing and ive run there shocks in the past on another rig and was happy with em
https://f-o-a.com/shop/f-o-a-2-0-inch-id-bumpstop-mounting-can-kit/
or
http://www.ridefox.com/product.php?m=offroad&t=shocks&p=3344&ref=filter
or
http://www.kingshocks.com/products/bumpstops/bump-stops-2-0/
...... almost forgot 1 heard good things about
http://www.profendersuspension.com/20-Bumpstop_p_92.html
I'm not sure what lift you have now nor your tire size.. but Bumpstops keep your shocks from topping out , they also keep an oversized tire from stuffing itself into your sheetmetal at full bump, which can be a bad situation for any tire and a number of your axle parts.
the part you listed will work for most situations regarding a lift.. Only reason I have the chosen stops is none of my suspension currently is factory...when I removed my coilovers we used HD buckets from Barnes4wd and shock towers from a F250...unfortunatly i have no factory parts or brackets left on the jeep..I'd love to be able to use something like the ones you listed...simplicity wins every time
Ohhh ok, haha I understand now why you are looking at those.
Reactions: GreenTJ
