The media blasting material I ordered from HD shipped through FedEx took 4 days to make it out of Wyoming. And 20 days to make it from Montana to California. I'm sure the cold weather isn't helping.
When you take a package 9 miles back and forth 3 times it takes a bit longer than normal. Closely look at the 4th through the 6th .Holly Shit 20 DAYS??? That is frickin crazy. I can understand getting a load across WY during the winter can be sketchy. I've driven across WY before when the freeway closed right behind me.
WY is the only place that I know of that has a McDonalds that has a drive-thru window for semis. They have a window high enough for them to hand your food right to you and the lane is made so you can get your tractor & trailer thru.
37" BFG Stickies?
I’ve said this a few times before, that Maxxis Razr is an interesting tire.BFG Krawler
https://www.bfgoodrichtires.com/tires/terrain/krawler-t-a-kx.html
Maxxis Razr's
https://ntwonline.com/37x12-50r17e-rbl-razr-mt-maxxis-tire/
MT Baja Pro XS
https://ntwonline.com/38x13-50x17c-baja-pro-xs/
Maxxis Trepador
https://ntwonline.com/37x12-50x17e-bsw-trepador-bias-maxxis-tire/
in that situation I would try those Mickies in a heartbeat. They are flat out nasty.Jeff ran the BFG Krawler in the 37" & 40" versions before and now has the Razr tires on his rig so I'm watching to see how he likes them.
Those Baja Pro XS is an interesting looking tire also and most of the reviews I've read say they are a good off-road tire but loud on the street. Since my Jeep is 85% off-road and trailered most of the time I ain't too worried about it.
Rick - I think the steering geometry is going to cause you a little bump steer. Can you lower the frame side track bar mount at all? Another option would be a difference pitman arm. Your drag link is flat enough you could run a completely flat pitman - that’s what I do - to maybe raise that side of the drag link a bit. It’s hard to tell how far your current steel pitman arm drops in the pictures.The TB is sitting at 8* and the drag link is sitting at 6.2*
