This intake is HEAVY and awkward to try and set in place so I am going to disassemble it as outlined in the instructions for additional porting.
This hopefully will allow me to mess around with it more and try to get it in place this third time around and not have any more leaks. Plus after talking to F&B again they suggested that I set the intake onto the engine without the gaskets and make sure everything is flat. NOT sure what to do if it isn't at this point but I'll cross that bridge when I get to it.
Additional porting:
If you are going to perform additional modifications to the manifold, please
follow the disassembly instructions below:
Remove fuel rails by removing the 10-32 screws holding the rails to the
mounts and the two short screws holding the throttle and TV cable mounts
to the fuel rail mount.
Remove outer throttle bodies as a pair by removing the 4 bolts per throttle
body and lifting them off the intake together.
Remove central throttle body
Do not remove the fuel rail mounts from the top adaptor plate, they have
spacers that are matched to the injector height.
You can leave the adaptor plate in place for porting, but do not use a
caustic agent to clean the top plate or the anodized finish will be
damaged. To remove the top plate, loosen the 12 flat head 5/16 screws.
To re-assemble the intake system reverse the operation. Do not use a
sealant on the top plate or throttle body gaskets. Torque top plate blts to 6
ft lbs. Throttle body bolts should be tightened until snug, approx 8ft lbs.
