I would put that intake on without gaskets and use some grease on the heads or intake. Drop it on there, put a little push on it from the bolts (no need to go full torque) and see where you're making contact. I'd expect one or another of the mounting surfaces is just a bit off and the intake is rocking back and forth. Maybe the thicker gaskets will get your there...but if you have a bad machine job, the time to find it is now.
The plan is to install the intake dry and use a feeler gauge to see if it is fitting properly. If I run into gaps at that point then I will try the grease idea or the molding clay stuff to see if It's a bad machining or warped intake manifold.
