the rear AntiRock is mostly used due to suspension design constraints
Are you familiar with how it's stiffness compares to stock?
I did and never looked backI have a front Antirock. It’s definitely a softer ride, but the increased body roll I could do without. Haven’t had much chance to really use it off-road. Most of my use is freeway travel.
If I were to do it again, I would go with an adjustable dual rate sway bar like the OffRoadOnly SwayLoc instead of the Antirock. It’s adjustable just like the Antirock, and also has two separate torsion bars for on-road and off-road that can be engaged at the flip of a switch.
I’m even considering ditching the Antirock and selling it to put in a SwayLoc.
Do you have the full Airock suspension? I’ve looked at that as an alternative to airbags in the coils. Looks great except for a small loss in suspension travel and increased complexityI did and never looked back
what wheels are those? I love that look and cant find the nameMine is set on the softest setting and happy to report a better ride on road, wasn't expecting that.
AND all the offroad flex .View attachment 74516
How?? I've run a 4-link rear and stock sway bar.
Coilovers? Where is the frame side sway bar mount relative to where the tower and frame cut needs to be?
ask Blaine
RearAre we talking rear or front? The rear is on completely the other side of the axle of the shock.
No I basically have a MC 4.5”. The Airock does look complex.Do you have the full Airock suspension? I’ve looked at that as an alternative to airbags in the coils. Looks great except for a small loss in suspension travel and increased complexity
... The Airock does look complex.
