All good posts. I’m always reminded when I see these threads you have to be thorough to diagnose your own stuff...everything from the control arm bushings, the track bars, the track bar bushings and bolts, sway bar frame bushings , sway bar links and bushings, all the steering linkage ends, hub unit bearings, ball joints, tires, shocks, alignment,bump stops ...it’s all one big interconnected system of chutes and ladders and every connection and setting is factored in by the manufacturer...I’m not trying to make it overcomplicated, but if you are going to fix your own stuff or want to be sure the shop shoots straight, you need to grasp how it all works together. Don’t be intimidated, take the time, you will be glad later you did if you plan to own one of these a while.
