my very first.
I was 16 and tapped somebody's back bumper pulling out of the high school parking lot. The exit went over a tin horn so I was going uphill and the girl in front of me was downhill, so the force on my bumper had a vertical/up component that pushed it up into the pop-up headlight of my 1985 Toyota Celica, rendering it stuck closed and inoperable, and busted the driver turn signal.
Cargo pants were only slightly more in style than they are today.
So I come home and immediately pull the bumper cover and bumper off, make some phone calls and find a bumper and a turn signal at a salvage yard on the south side of OKC, and go pick it up in my dad's Ranger. Come home and install it and guess what, it's exactly where the old one was because it wasn't the bumper that was bent, it was the freaking FRAME. I found a guy with a frame rack and paid him $50 to straighten it out, which I think was half what I paid for the bumper.
It's almost funny to think about those dollar amounts now but when I could buy a tank of gas for $12 and a good burger at a sit down restaurant for $8 including tip, wasting $100 on a bumper I didn't need was financially crippling.
Four years later I was building my first motor, for my '76 Datsun 280Z. I had set the timing chain and mounted the oil pan, valve cover was still off. A buddy stopped by and I showed him what I was working on and turned the motor a bit by the crank pulley bolt so he could see the cam turn (like myself a few weeks before, he was intrigued but had never seen inside a motor before). We talked a while and he left and I got back to work. Came back to see the link on the timing chain definitely NOT lining up with the dot on the cam gear, completely forgetting I had spun the engine. Thought I'd somehow screwed up the timing and tore into it only to remember I'd moved things, after I had the oil pan and timing cover off. A few bucks in new gaskets and put it back together.
I'm happy to report my metabolism has slowed since then and I no longer weigh 155lbs.
A couple more weeks later I took the car for its break-in drive and warm-up for setting the valve lash. Pulled the valve cover to find milkshake. Went ahead and set the valve lash, then had the motor back out in about 45 minutes and somehow figured out the leak was in the timing cover gasket (because the water pump mounts to the timing cover and the coolant passes through the timing cover gasket on the way into the block) and I've believed ever since that it was probably sealed just fine before I took it off to fix the timing that was already fine.
Man I like that you were young and not afraid to tackle stuff- very cool.
I guarantee you’ve been the kind of guy that can take care of his family and can fix his wife’s flat tire.
We need more of that today.
