Genright 19.5 Gallon EXT Stretch Tank Measurement Request
I asked two very specific questions about a very specific gas tank. I didn't ask about other gas tanks.
And I asked a general question about 2 different tanks. So what is the problem? Asking why someone chooses one item over an other is a common question.
The fundamental problem is that your gas tank doesn't answer my questions because it is a different gas tank. Everything fell apart from there.
  • Face Palm
Well I guess my gas tank doesn't measure up to your standards....
Reactions: Tob
It doesn't do what I need it to do. Nothing more.
And this is why I know you are being entirely disingenuous with whatever it is you are doing right now.
I was asking a SIMPLE question. How it doesn't do what you need it to do I have no idea since you WON'T just answer the question.
It's in YOUR mind that I'm being disingenuous.
Your tank is too big for my purposes. It is physically bigger than the tank I'm asking about. Take a look at that 14.34" dimension compared to yours. That is why I don't care about your tank.
Would SEEM to me that the area where IT MATTERS which is where the axle meets the tank that there is more room in the Comp 20 tank.
But you only asked about 2 measurements so who knows.
not what you asked but, Boyd fab.
make you any shape, depth or width you want and probably not near 1500$. if you get bored take a peek. they also have/use the fuel pump rings that fits our pump assy's.
they are tank makers not fender sellers, not suspension peddlers, just tanks and if we could get into their head i bet they could have a better under body stretch tank and/or a better cell with baffle walls and a sump or trap. and be 1/2 the cost of GR.
Reactions: jjvw
I don't think anyone is against Boyd Fab. The issue for me would be getting them the correct dimensions and you have to start somewhere. You can work off of existing dimensions and alter them, build a full scale mock-up, or just wing it. I'd rather start with something known and work from there.
If I were to go through the trouble of fabbing from scratch, I don't think I would put it in the stock location anyway.
I would and that gives me the opportunity to solve my current problems so I could get a rear AR through. Currently, the only place I can sneak the bar through is filled with tank roll-over valves and aluminum. It could easily be optimized if I started from scratch but with this tank as an example of what needs to change.
Reactions: B00mb00m and jjvw
And just so we are clear Rick is one if the people on this forum that is always helping people without attitude nothing more nothing less
  • USA Proud
Reactions: Tob
I often make the following statement in trying circumstances based on a full lack of understanding as to what is needed.
Based on what you're doing it is hard to tell whether you are helping me or fucking me.
Reactions: jjvw
I don't care about his gas tank or the other gas tanks. He should take the hint.
I get that but a little less attitude from you will ensure we can ask questions and discuss without fear of being belittled ya feel me?
I dont understand or care what you are trying to say I'm not in a crypt reading mood this morning
No. I'm sticking to my guns that I wasn't the problem here.
Reactions: MikeE024
