I know this is a shot in the dark, old thread and all.
I'm looking for constant tension clamps for the cooler hoses going from the transmission lines to the bottom of the radiator. I'm kinda sorta sure the size is 3/8" ID Gates transmission hose. I know that someone will ask why I don't just climb under and see for sure what size hose: really bad back, would like to have what I need to do the repair when I climb under there b/c it will be a task.
They have gear worm clamps on there now, I hate those clamps, especially on smaller diameter hose and as things go I have a big time leak on one of them. They lasted a couple years but I've always wanted to change them.
Want to replace the hoses and the clamps on both ends. Looking for the size of clamp I'd need or if someone knows a link to some. I'm not sure if I'm looking for a clamp with the same diameter as the hose O.D. or if it needs to be smaller.
Edit:
2001 Jeep TJ, 32RH transmission, stock radiator
