Genright universal crossmember question
Is it cheating if it works?
Nope!
I changed my 04 auto trans mount, I'm in there why not. The vibes where absolutely horrific. I swapped my OE mount back in and smooth as silk.
Have you found any auto trans mount alternatives? Vibes where so bad I was like wtf am I gonna do when these things aren't available. I started thinking about making some weird cross member that uses the rubber motor mounts. :oops: I still may try it...just to try.
Nope!
The one from napa works fine.
Nope!
I've been able to get OEM so I haven't looked.
Reactions: Fluxor
I used a 2004 Chevy truck trans mount when I built my crossmember. I doubt it will need to be replace anytime soon, but the mount is less than $10 and in stock at any parts store.
Thanks I will check it out. Maybe it was just the hard as a rock turd I got from autozone. With 190,000 on the odometer I want to change it and would like a suitable replacement that doesn't cost $140, if that's possible.
Kinda my same thoughts, I plan on a flatter belly and this will need addressed. The trans mount just has to be as soft as the OEM without presenting less clearance or strength.
If we can’t make our own which mount will be better?
Genright, TMR, Dave’s?
if your gonna ditch the OE rubber it really doesn't matter which 1. pick the one that seems best for your application or easiest to incorporate with the least amount of modification.
If you're going to do one of those, then you can build your own as you're building one of theirs anyway 🤷
Reactions: someguysjeep
