Picked up some 3x3x1/4” aluminum angle for my preferred cost of nothing.
It will become some rocker guards until I can come by some 6x6x1/4” Steel angle.
Also found some aluminum diamond plate that I haven’t decided on a use for.
Who says our TJ's can't haul chit!
Didn't really do anything but drive home from work, but on the way I noticed this:
You'll note the -0- mph...I took this photo while stopped at a traffic light :cool:
Haha, I secretly checked all of your gauges to compare them with mine, but the only one that looks different at a stop is the fuel gauge on mine almost always reads way lower than yours!!
I cleaned the IAC the other day, which wasn't too bad, but I decided to remove the throttle body and do the job properly. It was fairly easy to do.
I did have a bit of a high idle when I started up, I just squirted some throttle body cleaner in the IAC port while it was running and that seemed to fix it. Must have been a little bit of crap stuck in there. My TJ is the 2006. So the IAC valve is a bit different to older TJ's
Searched for the source of my AC leak with the fancy glasses/UV light. No sign of any dye, which leads me to believe it's leaking in the HVAC box where the evap is. Ugh!
