Radio antenna adapter
mrblaine
Crew Member
Quail Valley, CA
I believe the factory radio antenna connection at the back of the radio is called a Motorola. Near as I can tell anyway. I am using a JK antenna which has a very tiny connector on the end.
The problem is I have not been able to figure out what that end is called to locate an adapter from it to Motorola. We have bought a couple and returned them because they are wrong and the few stereo shops we have visited don't know either.
Help.
I wonder if it's this one.
https://www.crutchfield.com/p_12040CR10/Metra-40-CR10-Antenna-Adapter.html?tp=2569
When I did the system in my jeeep a couple years ago, they sent me this adapter but it didn't fit.
When I called Crutchfield the rep told me it was for later jeeps.
I believe I still have it and could mail it to you.
No idea which is why I put up the post. I haven't been able to find the terminology that accurately describes what is on the end of the later antenna to adapt it to the factory 97 head unit.
can you post up a pic. some use motorola ends, some use a FAKRA end.
according to what I see, There is also antenna cable that goes between the mast cable and the radio itself.
The part number for that is 56040948AG. You would then need Metra Part #40-eu10 to adapt that cable to your radio.
Is there a specific reason that you are using the JK style antenna?
I found a stainless antenna mount that says it only works on the JK. I may have to revisit that.
Can you remove the cable from the mount? And replace with a style that fits your tj..
