pichers or it di'int happenChanged the oil and filters. Installed morryde system for spare tire, installed trail tail lights, pulled the factory console out and mocked up for 30mm ammo can console so I’ll have some cheap lockable storage.
What padding did you use and how did you attach it on your roll bar? Thxsince our brutal winter seems to be over (sunny 70⁰) I took the hardtop and full doors off and put the half doors on
“Road Closed” means “come see why this sign is here.”since our brutal winter seems to be over (sunny 70⁰) I took the hardtop and full doors off and put the half doors on
Very nice.since our brutal winter seems to be over (sunny 70⁰) I took the hardtop and full doors off and put the half doors on
Are they yellow?Installed the stainless steel CB antenna mount. Still need to drill the hole for the extra ground to tub bolt, but I can do that anytime.
Also ordered the CB mount that mounts to the footman loop on the windshield.
Or even, pictures or it didn't happen.pichers or it di'int happen
Seems a little extreme, even for a Trekkie.Going to get the slashed one vulcanized for another spare.
Wait I thought you were ordering the Bkack and Yellow onesView attachment 306224
Ordered these today, complete with seat heaters!
Nice Toasted buns....View attachment 306224
I did that with mine too… and added a false bottom to the inside so stuff didn’t fall all the way down.Just need to cut the relief in the back lip of the ammo can and find some bolts. Thanks @jvvw
