Probably not the best way to phrase the question.
I’ve got a dual optima setup and a battery isolator. 12v to the isolator bridges the two batteries in order to charge the secondary while driving.
I’m about to put in a solid state 8 switch panel and one in the many switch labels gave me an idea. Why not have a second way to bridge the batteries? Push a switch to send 12v from the first battery to the isolator and bridge the two when I’m not driving.
I wouldn’t do it often, but there have been times when I haven’t had enough sunlight one day for my solar panel to keep the second battery topped off, and I don’t want my fridge to shut off. I’d press the switch to use my primary as a bit of reserve power.
I’m not worried about getting stranded. I’ve got a buddy with me in most camping trips and I also bring a portable jumper.
So in wiring this, should I use diodes on both 12v power in to the isolator to prevent power going “backwards”? More worried about frying my new solid state switch.
