I don’t get above 45 on the way to work? Never heard a thing!Wow, how is it possible there was no noise?!?!
Lol…..I posted a video…..omg!Are you sure the carrier shims aren’t missing. I’ve never seen that kind of play from worn carrier bearings.
Yep posted a video after I got it out all I can say is CRAPAfter watching that video; the axle bearings are definitely shot and I would bet the ring and pinion gears have abnormal wear; which is where the all the sparklies are coming from.
Lol. You called IT!What do I win?
the shims were there. But I cannot imagine what did the bearings in. The passenger side was real real bad, the driver side was half the wear but still very bad.Are you sure the carrier shims aren’t missing. I’ve never seen that kind of play from worn carrier bearings.
Mine did too, found it when I put in my locker and replaced them. My shop said those bearings never fail, obviously that's not the case. I put 30k on the gears after replacing the carrier bearings so I don't think it hurt my gears. Obviously I wasn't paying much attention to glitter in the oil.Mine had bad pitting
