Stop me if this already exists, but I thought it might be nice to have a list of what XJ parts fit on TJs. I see XJ part-outs every now and then, and sometimes I wonder what could be used.
If others reply, I'll update the list below.
Update: The list below is just a collection of comments on this thread. I can't take credit (or blame!). If something looks wrong, drop a comment and I'll update it.
Engine:
- From an engine harness, many connectors and stuff (like the PDC) should be the same.
- 4.0
- Engine block mounting holes differ. Think the XJ block is the same for a 97-98 TJ. Then 99-06 used same block as WJ.
- Various horsepower and torque changes over the years but displacement remained the same.
- 1991 they went to the HO (high output) engine but the change wasn't that much.
- 2.5
- 2.5L was in the base model XJs 84-96.
- 2.5L was also available in ‘97-‘01 XJs and is a straight swap to the TJ.
Drivetrain:
- Transfer Cases:
- 231 transfer case should be the same.
- Front Axle
Suspension:
- Front Suspension
- The front suspension is the same (control arms, track bar, steering linkage).
- Some differences in disc brake rotor dimensions (mid '99) on the Dana 30 and axle disconnects.
- Smaller 260 U joints in early XJs.
- Wheels (5x4.5 lug pattern)
Interior:
- Steering Wheel (pre-2003), Airbag, and Clock Spring
- Not sure. Can anyone confirm?
- Gauge Cluster Bezel and Lens
- Not all gauge clusters themselves can swap, see here.
- Stock Stereo
- Fog Light Rocker Switch
- Wiring colors are different though.
Sensors:
