thats what the plumber said too !it's not a crack it's the shadow on a rib of the casting.
That looks like the knuckle off an Alaskan beach truck. The ujoint does not show and signs of leaking but that also means that there may not be any grease left in them either. Do you have any clicking or pulsations in the steering wheel while turning? From the looks of things you are well overdue for some TLC there.
Not on that it won't be.I have heard replacing U joints is not an easy task
12 point what? LOL. They are completely stripped
Ha, what 12 point indeed !I have heard replacing U joints is not an easy task
The way those look, I'd just replace them with a new 4340 set. Those u-joints are running on borrowed time! For around $500, complete, it's money well spent. Removing the axles is actually the easy part. Like I said, the hard part will be getting those 3 bolts out on each side.I worry about taking the knuckle off because that means i have to take out the axle and that is something i have never done
Believe it or not no, nothing. It drives just fine but clearly they need replaced.That looks like the knuckle off an Alaskan beach truck. The ujoint does not show and signs of leaking but that also means that there may not be any grease left in them either. Do you have any clicking or pulsations in the steering wheel while turning? From the looks of things you are well overdue for some TLC there.
Yeah I am really not looking forward to wrestling with it but I have to learn some time so I guess now is that time lolThe way those look, I'd just replace them with a new 4340 set. Those u-joints are running on borrowed time! For around $500, complete, it's money well spent. Removing the axles is actually the easy part. Like I said, the hard part will be getting those 3 bolts out on each side.
Mine drove perfect and looked way better than yours. Removing them revealed the needles were dryer than a popcorn fart. They fell out and vanished before my eyes. POOF!Believe it or not no, nothing. It drives just fine but clearly they need replaced.
Do it yourself. You'll be sore afterward; there's no doubt. But you'll also be sore from kicking yourself if you don't do it and it fails on the road. It's not that hard of a job. In your case will just take time, a decent press, maybe some heat, and a whole shit ton of elbow grease. You won't like the quote a mechanic will give you for the job after he takes a look at it.Yeah I am really not looking forward to wrestling with it but I have to learn some time so I guess now is that time lol
Well I guess there is a first time for everything. I've never done ujoints but we will seeMine drove perfect and looked way better than yours. Removing them revealed the needles were dryer than a popcorn fart. They fell out and vanished before my eyes. POOF!
Yeah the last thing I want is a breakdown that I cannot recover from. I guess I will try my best. You all have been awesome so thank you for the supportDo it yourself. You'll be sore afterward; there's no doubt. But you'll also be sore from kicking yourself if you don't do it and it fails on the road. It's not that hard of a job. In your case will just take time, a decent press, maybe some heat, and a whole shit ton of elbow grease. You won't like the quote a mechanic will give you for the job after he takes a look at it.
