The clear solution is Tons and Fodeez.the wheel got hit so hard it ripped the shock off the top end and crumbled the CA's. and looks like it took most of the impact.
my mention of a bent shaft would be the best problem in this instance, but if 1 had to put money on it if the wheels not wobblin (and should have been checked at the shop) it's toast. costs more to get straightened than it costs to replace.
So what you're saying? You dont think its bent?If the shaft was bent that far you could easily see the wheel wobble. The rotor would also be moving back and forth in the caliper. I’ve bent shafts a lot less than that and it has always been very noticeable. I can’t imagine the alignment guy would not have noticed that, but who knows.
Gotcha - I was thinking disk brakes. It is easy to check. Put the rear up on jack stands and run it. If the axle shaft is bent the tire will not turn true - it will wobble.So what you're saying? You dont think its bent?
No rotor/caliper on rear axle. This is a 97.
Do alignment shops turn a tire to see if the toe out follows on a rear in case it has a bent axle shaft or bent rim?I agree - I think there should be almost 0 toe in the rear, but it is pushing 2 degrees. The axle housing is definitely bent.
I don't think so, but don't know for sure. But if I saw a solid axle with that much toe I'd take a second look.Do alignment shops turn a tire to see if the toe out follows on a rear in case it has a bent axle shaft or bent rim?
We would have already idled it in gear with the rear axle on jack stands.I don't think so, but don't know for sure. But if I saw a solid axle with that much toe I'd take a second look.
Most do not. I would put it up on jackstand and run it to see if it has a whobble to it. The flanges bent pretty easily.Do alignment shops turn a tire to see if the toe out follows on a rear in case it has a bent axle shaft or bent rim?
I was in the auto business for 30 years, that’s why I recommend checking it. Unfortunately some mechanics will be trained to do a task and not really understand it. I saw a guy that would just drive the car and bill it then if it came back he would align it. That was before the computer printout.If the shaft was bent that far you could easily see the wheel wobble. The rotor would also be moving back and forth in the caliper. I’ve bent shafts a lot less than that and it has always been very noticeable. I can’t imagine the alignment guy would not have noticed that, but who knows.
They may or may not, I would think the shop would have noticed when calibrating the head. But very few mechanics these days go the extra mile or couple steps in this case. I worked is a dealer with 30 techs and I might let 3 work on my personal vehicle.Do alignment shops turn a tire to see if the toe out follows on a rear in case it has a bent axle shaft or bent rim?
Got it. At maybe just easier and cheaper to just swipe out the entire axle. Found few good ones for $400-800.Gotcha - I was thinking disk brakes. It is easy to check. Put the rear up on jack stands and run it. If the axle shaft is bent the tire will not turn true - it will wobble.
I think what we are saying is that with the evidence here, the axle housing is most likely bent from the impact. But, the shaft could also be bent and is worth checking.
The body mounts did not shift. Most of the impact was at the tire, rim is ok, but tire go destroyed, and the controls arms bent.Most do not. I would put it up on jackstand and run it to see if it has a whobble to it. The flanges bent pretty easily.
A couple things I would want to know.
How hard was he hit and how fast.
Was the impact mainly on the tub or was the wheel hit also.
Did you look at the body mounts to see if they are shifted.
Only if you ever want to use 4WD again.Do the front and rear gear ration must match?
3.55 is a fairly rare ratio since it only came on 97-98 TJs, you might have to regear your replacement axle. On 97-98 they were either 3.07 or 3.55. On 99 and newer they're all either 3.07 or 3.73.Do the front and rear gear ration must match?
I am searching for rear axle assembly, mine is a Dana 35 with 3.55, and Dana 30 at the front.
Crap, I need the 4x4 around here. Base on these old images I found, its definitely a 3.55.3.55 is a fairly rare ratio since it only came on 97-98 TJs, you might have to regear your replacement axle. On 97-98 they were either 3.07 or 3.55. On 99 and newer they're all either 3.07 or 3.73.
And yes the front and rear axles must match, though the front and rear ratios differ by .01. 3.07/3.08, 3.54/3.55, 3.73/3.74 etc. That .01 is not a problem since 4x4 is only supposed to be used on low traction surfaces. In 2wd it doesn't matter, the front could be 5.38 and rear 3.07 and it wouldn't matter. So if you found a replacement axle that was good but its ratio didn't match the front ratio you could still drive with it so long as you avoided all use of 4Hi or 4Lo.
285/70R17What size tires are you running now? Your Profile is empty so far as basic Jeep information goes. 4.10 may or may not be a good choice of ratio.
That's essentially a 33" tire. With your 4.0 engine and 5-speed transmission 4.56 would be a much (!) better all-around ratio that would produce ideal highway engine rpms.285/70R17
