I also bought the Brassworks heater core and while it is definitely quality stuff the heat output is barely adequate at best.Wow, I’ve started poking around more online, and it seems no one is satisfied with their heater core. Someone who installed an expensive brassworks one said it was very disappointing in terms of heat output. At this point I just want something decent that I don’t have to wait 18 weeks for. Any other ideas?
+1 for the Superior cooling systems unit that "SvtLdr" sent a link to. I would wait and get that one when its back in stock.
Both Radiator Express and Superior Cooling Systems are using the same exact set of product photos (at least for the model I need). In fact, I've even seen these exact same images on random eBay sellers as well. That leads me to believe that they are all getting them from the same source and just slapping their own label on it...This is all good feedback, multiple sources reporting the Brass Works unit doesn't put out the same heat. Thanks everyone.
Does anyone have first hand experience with the Radiator Express unit?
I just checked with a local radiator repair shop. Worst case scenario, if a brand new core was required, the bill would be around $150. Sounds like most of the time they're able to just clean the core and repair whatever is leaking which keeps the price a lot lower. He also offered to test the old heater core and provide an estimate for free. I think I'm going to start there as my Jeep is parked for the winter anyways. Thanks for the suggestion @tr21triton .has anybody tried taking it to a shop that rebuilds radiators and seen if they could rebuild a heater core ? i know there aren't alot of shops around that still do this but might be worth a try .....
good to hear. i've noticed a slight antifreeze smell in mine the last few weeks and had planned on looking into this option when i get around to it !!!!! i hope it makes it to spring,I just checked with a local radiator repair shop. Worst case scenario, if a brand new core was required, the bill would be around $150. Sounds like most of the time they're able to just clean the core and repair whatever is leaking which keeps the price a lot lower. He also offered to test the old heater core and provide an estimate for free. I think I'm going to start there as my Jeep is parked for the winter anyways. Thanks for the suggestion @tr21triton .
That's how mine started. The faint smell got stronger eventually producing an oily fog on the windshield. Then I started noticing a small leak collecting on the passenger front foot well. It was then that I bypassed the heater core and parked it for the winter. Good luck to you.good to hear. i've noticed a slight antifreeze smell in mine the last few weeks and had planned on looking into this option when i get around to it !!!!! i hope it makes it to spring,
I just picked up my OE core from the repair shop. They found two small leaks and were able to repair them both. They also tested it for both pressure and flow. $95 later I'm back in business.I just checked with a local radiator repair shop. Worst case scenario, if a brand new core was required, the bill would be around $150. Sounds like most of the time they're able to just clean the core and repair whatever is leaking which keeps the price a lot lower. He also offered to test the old heater core and provide an estimate for free. I think I'm going to start there as my Jeep is parked for the winter anyways. Thanks for the suggestion @tr21triton .
Great break here!I just picked up my OE core from the repair shop. They found two small leaks and were able to repair them both. They also tested it for both pressure and flow. $95 later I'm back in business. View attachment 312968View attachment 312971View attachment 312969View attachment 312970
Personally I'd get the ADPI/PRO on Rockauto for about $40 if I wanted good performance and the Brassworks if I never wanted to pull the dash again.Anyone have a good line on a replacement for the later tj cores?
Thanks, The brassworks is an interesting one. Never pulling the dash again sounds nice but the part not heating very well is lame as that is it's sole purpose really.Personally I'd get the ADPI/PRO on Rockauto for about $40 if I wanted good performance and the Brassworks if I never wanted to pull the dash again.
