Jeep TJ O2 Sensor Guide (Symptoms, Codes, Replacement & Fixes)
Chris
Administrator
Staff Member
Gillette, WY
What are Bank 1, Bank 2, etc.?
Since this question pops up from time-to-time, here's an easy to follow diagram that illustrates what they mean when your OBDII code scanner (or manual) tells you something like "O2 sensor, Bank 1, Sensor 2":
What does upstream and downstream mean?
Simple, upstream means the O2 sensor is "upstream" of the catalytic convertors, meaning before the catalytic convertors. Downstream means the O2 sensor is "downstream" of the catalytic convertors, meaning after the catalytic convertors.
What brand of O2 sensors should I use for replacements?
Pay close attention to this one so you can do it once and do it right! The Jeep Wrangler TJ is extremely sensitive to all oxygen sensors other than NGK / NTK / Mopar. Bosch O2 sensors and all the others (including the crappy Chinese brands you'll buy at your local auto part store) are very well documented as not working properly with our TJs. In other words, you plug them in and you assume all is well, until you notice your check engine light isn't going away. This is almost always due to the fact that you didn't use an NGK / NTK / Mopar replacement O2 sensor.
Okay, so why don't other sensors (i.e. Bosch) work on our Jeeps?
Glad you asked! Check out this video for a detailed explanation of why other brands of O2 sensors don't work on our TJs:
So which O2 sensors do I need?
I'm going to break down which sensors you need based off what year your TJ is. The part numbers (and information) below were taken directly from the NGK website, so you can assure it is 100% accurate (even double checked each individual year and model before writing this thread).
Be aware that NTK O2 sensors are the same thing as NGK and they share the same part numbers. NTK is owned by NGK, it's simply their division for O2 sensors.
4 Cylinder Engines
1997-2000
NTK #23179 - Bank 1, Sensor 1 (Upstream)​
NTK #23151 - Bank 1, Sensor 1 (Upstream) (1998 ONLY)​
NTK #23179 - Bank 1, Sensor 2 (Downstream)​
2001-2004
NTK #23138 - Bank 1, Sensor 1 (Upstream)​
NTK #23141 - Bank 1, Sensor 2 (Downstream)​
2005-2006
NTK #23159 - Bank 1, Sensor 1 (Upstream)​
NTK #23159 - Bank 1, Sensor 2 (Downstream)​
6 Cylinder Engines
1997-1999
NTK #23151 - Bank 1, Sensor 1 (Upstream)​
NTK #23099 - Bank 1, Sensor 2 (Downstream)​
2000 (Federal Emissions)
NTK #23122 - Bank 1 Sensor 1 (Upstream)​
NTK #23179 - Bank 1 Sensor 2 (Downstream)​
2000 (California Emissions)
NTK #23506 - Bank 2, Sensor 1 (Upstream)​
NTK #23110 - Bank 1, Sensor 2 (Downstream)​
NTK #23179 - Bank 2, Sensor 2 (Downstream)​
2001-2003
NTK #23139 - Bank 1, Sensor 1 (Upstream)​
NTK #23138 - Bank 2, Sensor 1 (Upstream)​
NTK #23142 - Bank 1, Sensor 2 (Downstream)​
NTK #23141 - Bank 2, Sensor 2 (Downstream)​
2004
NTK #23137 - Bank 1, Sensor 1 (Upstream)​
NTK #23135 - Bank 2, Sensor 1 (Upstream)​
NTK #23132 - Bank 1, Sensor 2 (Downstream)​
NTK #23531 - Bank 2, Sensor 2 (Downstream)​
2005-2006
NTK #23018 - Bank 1, Sensor 1 (Upstream)​
NTK #23160 - Bank 2, Sensor 1 (Upstream)​
NTK #23158 - Bank 2, Sensor 2 (Downstream)​
Misc Installation Notes
When installing new O2 sensors, be certain to use some anti-seize on the threads of the new O2 sensors! This is important, and will save you a huge headache should you ever need to remove them in the future.
In addition, a O2 sensor socket will greatly aide in the installation and removal of O2 sensors. I recommend this one.
Lastly, if you notice your O2 sensor harnesses are not long enough with the new O2 sensors, these O2 sensor extensions will solve the problem.
Given that NGK / NTK O2 sensors are now being discontinued, I felt that it was time to update this thread. For a long time in the TJ community it was well known that NGK / NTK O2 sensors were the only ones that didn't have issues with reoccurring OBDII error codes. Fortunately it would appear that many others in this thread have found a solution. Walker O2 sensors have been widely reported to be trouble free with our TJ PCMs.
Because of all the good feedback I've been hearing about Walker O2 sensors, I'm going to update this thread below to include all of the Walker O2 sensors (as well as links) for each year and model of TJ. Thanks to all of you who have reported on the Walker O2 sensors for making this possible.
FWIW, Walker sensors are made in Japan. This is a very good thing and a big step above any of the crap quality Chinese sensors you'll find at Autozone and the likes.
4-Cylinder Engines
1997
-2000
250-24942 - Bank 1, Sensor 1 - OE Base Sensor
250-24943 - Bank 1, Sensor 2 - OE Base Sensor
350-34511 - Bank 1, Sensor 1 - OE Replacement
350-34439 - Bank 1, Sensor 2 - OE Replacement
2001-2004
250-24345 - Bank 1, Sensor 1 - OE Base Sensor
250-24345 - Bank 1, Sensor 2 - OE Base Sensor
350-34320 - Bank 1, Sensor 1 - OE Replacement
350-34320 - Bank 1, Sensor 2 - OE Replacement
2005-2006
250-24253 - Bank 1, Sensor 1 - OE Base Sensor
250-24253 - Bank 1, Sensor 2 - OE Base Sensor
350-34039 - Bank 1, Sensor 1 - OE Replacement
350-34039 - Bank 1, Sensor 2 - OE Replacement
6-Cylinder Engines
1997
-2000
2001-2003
250-24259 - Bank 1, Sensor 1 - OE Base Sensor
250-24259 - Bank 1, Sensor 2 - OE Base Sensor
350-34320 - Bank 2, Sensor 1 - OE Replacement
350-34320 - Bank 2, Sensor 2 - OE Replacement
350-34598 - Bank 2, Sensor 1 - OE Replacement
350-34598 - Bank 2, Sensor 2 - OE Replacement
2004
250-24460 - Bank 1, Sensor 1 - OE Base Sensor
250-24253 - Bank 2, Sensor 1 - OE Base Sensor
250-24259 - Bank 2, Sensor 2 - OE Base Sensor
350-34592 - Bank 1, Sensor 1 - OE Replacement
350-34039 - Bank 2, Sensor 1 - OE Replacement
2005-2006
250-24680 - Bank 2, Sensor 1 - OE Base Sensor
250-24460 - Bank 2, Sensor 2 - OE Base Sensor
350-34213 - Bank 2, Sensor 1 - OE Replacement
350-34592 - Bank 2, Sensor 2 - OE Replacement
OE Base Sensor vs OE Replacement Sensor
From what little information I can find, it sounds like the "OE base sensor" is designed to be a direct replacement for OEM NTK sensors, and the "OE replacement" is a less expensive or "economy priced" version. More or less a premium vs economy thing.
It would be interesting to see which versions those who have been using Walker went with. Does the economy fall victim to the same sensor error issues that most aftermarket sensors do? Is the Base the version that line that people have been having good luck with?
These 2 videos are where I am drawing my assumption:
You have to pay very close attention the language being used. At first view I thought the videos were the same.
At 1:08 "Walker's aftermarket oxygen sensors" video titled "...OE Replacement..."
At 1:23 "With our Walker Original Equipment oxygen sensors" video titled "...OE Based..."
I just replaced all of the O2 sensors on my 2004 4.0, and Rockauto shows NTK 23531 for bank 2 sensor 2 instead of 23131... Did I put the wrong one in or are these interchangeable? I haven't had any issues in the month since I installed it though.
Also, for those here researching O2 sensor codes, mine threw an O2 sensor code, but I'm not sure any were actually bad, because the root of the problem was one of the precats broke up and was clogging the exhaust... But I was at 90k miles and decided to replace all the sensors anyway while I replaced the cats. So make sure there isn't some other problem causing the O2 code. If you're on all original parts and getting up there in miles it might be a good idea to just replace everything anyway - it's easier to access the O2 sensors when the downpipe is out. Total cost for 4 sensors and downpipe with precats and new cat was about $450. I probably could have saved a few $ somewhere else, but Rockauto was able to get everything to me the fastest.
Nope, you're right, I'm wrong!
I had typed 23131, when it was actually 23531... In other words, my fat finger hit the 1 instead of the 5!
I'll go back and double check I didn't do that with any others. Thanks for the heads up, much appreciated!
I replaced all 4 and still get the same error codes, but the Jeep runs great......
Not sure what codes you're getting, but it could be something else (i.e. cats).
Reactions: Don A.
Thanks for such a great resource! A couple of my O2 sensors have gone bad (soooo hard on fuel!) so I'm replacing all 4 as preventative maintenance.
Good idea! For the price, it makes sense to do them all at once!
All replaced and no more error codes! Hopefully my mileage improves.
*To anyone looking to replace their O2 sensors* I'd reccomend a breaker bar, penetrating lube, and some kind of torch (all I had was a small propane torch). It took me just over 2 hours to do all mine and the breaker bar (or pipe slid over a ratchet) was needed a few times. I also bought the O2 sensor socket for $10 and it was totally worth it. Total investment was about $250 for all 4 sensors plus the socket.
Yep, they likely didn't have anti-seize on the old ones.
As I mentioned in my original post, when installing new O2 sensors, be certain to use some anti-seize on the threads of the new O2 sensors! This is important, and will save you a huge headache should you ever need to remove them in the future. You know first hand what I'm talking about now!
Reactions: FaithG
10/10 would recommend anti-seize. The sensors I bought came with anti seize already on the threads but I added extra just to be safe
Just wanted to take a minute to thank the folks on this thread. I just changed all four oxygen sensors on my 2005 LJ and this thread was perfect. Thanks for taking the time.
Glad you were able to get use out of it. A thread like this has been long past due, so I was happy to write it.
Had a P0150 Bank 2 Sensor 1 "slow response". This happened off road and the CE light went away the next day. Any concerns?
No, that's fairly common when off-roading. I wouldn't ever worry about it unless it came back and the code refused to go away.
Reactions: Michael Roberson
I got a lot of info from this thread Chris and I took your advice regarding NGK parts. I finally had the time to replace the sensors and now it idles like a dream. I appreciate all your work.
Good to know! The NGK O2 sensors aren't that much, and they're the only sensor out there that is proven to work with our finicky TJs. Definitely not worth saving a few dollars to go with the crappy Chinese ones they sell at your local auto part stores.
Pay close attention to this one so you can do it once and do it right! The Jeep Wrangler TJ is extremely sensitive to all oxygen sensors other than NGK / NTK. Bosch O2 sensors and all the others (including the crappy Chinese brands you'll buy at your local auto part store) are very well documented as not working properly with our TJs. In other words, you plug them in and you assume all is well, until you notice your check engine light isn't going away. This is almost always due to the fact that you didn't use an NGK / NTK replacement O2 sensor.
4 Cylinder Engines
1997-2000
NGK #23506 - Bank 1, Sensor 1 (Upstream)
NGK #23099 - Bank 1, Sensor 2 (Downstream)
2001-2004
NGK #23138 - Bank 1, Sensor 1 (Upstream)
NGK #23141 - Bank 1, Sensor 2 (Downstream)
2005-2006
NGK #23159 - Bank 1, Sensor 1 (Upstream)
NGK #23159 - Bank 1, Sensor 2 (Downstream)
6 Cylinder Engines
1997-1998
NGK #23151 - Bank 1, Sensor 1 (Upstream)
NGK #23099 - Bank 2, Sensor 2 (Downstream)
2000
NGK #23122 - Bank 1, Sensor 1 (Upstream)
NGK #23506 - Bank 2, Sensor 1 (Upstream)
2001-2003
NGK #23139 - Bank 1, Sensor 1 (Upstream)
NGK #23138 - Bank 2, Sensor 1 (Upstream)
NGK #23142 - Bank 1, Sensor 2 (Downstream)
NGK #23141 - Bank 2, Sensor 2 (Downstream)
2004
NGK #23137 - Bank 1, Sensor 1 (Upstream)
NGK #23135 - Bank 2, Sensor 1 (Upstream)
NGK #23132 - Bank 1, Sensor 2 (Downstream)
NGK #23531 - Bank 2, Sensor 2 (Downstream)
2005-2006
NGK #23018 - Bank 1, Sensor 1 (Upstream)
NGK #23160 - Bank 2, Sensor 1 (Upstream)
NGK #23158 - Bank 2, Sensor 2 (Downstream)
I
4 Cylinder Engines
1997-2000
2001-2004
2005-2006
6 Cylinder Engines
1997-1998
2000
2001-2003
2004
2005-2006
